69z-28
02-15-2007, 10:45 PM
well i have my fuel source coming from the shrader valve, then into about a one foot long 4an line then into my flo through manifold pictured here....http://www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=217
then i have the fuel pressure sending unit and Fuel pressure safety switch mounted to it, and the fuel solenoid on the outlet side.
well i smelled fuel constantly since i installed my kit so i finally found where its coming from. all of the NPT fittings have carefully wrapped teflon tape, but on the FPSS, sending unit as well as the fitting INTO the fuel noid, they seem yellowish/brown like fuel has saturated them. well i crank the hell outa all the fittings and made them much tigher, but im afraid im about to strip the fitting into the noid anyways, theyre all pretty tight and i wiped everything down and got it all dry and turned the key on to get the fuel pressure up there and it began leaking somewhat slowly but steadily from the manifold, and it seems as if its leaking from in between the female swivel port and the hexagon/octagon body of the manifold where the actual accesory ports are located. im not sure if it has something to do with being a swivel fitting but im pretty sure its leaking mostly from there. should it be doing this for any reason. i can tigthen it more, but i dont wana break or strip anything. would i be better off going with a solid one like this.... http://www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=27
however, obviously i wont be able to turn my accesories exactly where i want them. any help is great.
