camaro stuck
wakebordr2006
02-15-2007, 12:25 PM
my camaro is stuck on a pile of snow that turned to ice. it seems like the frame of the car is just resting on it which sucks cause the tires just barely touch the ground. any tips to getting it off w/o calling a tow truck or waiting for the ice to melt? haha
Don350k
02-15-2007, 01:00 PM
Jack it up and put blocks under the wheels
nodnarb481
02-15-2007, 01:37 PM
chisel away at the snow and ice? thats what i have to do when i get home because the rear wheels are stuck on snow and ice for some reason..
Fast Orange
02-15-2007, 01:47 PM
start it and just let it run?.. turn the heater on full blast.. be sure to keep a hole in front of the radiator so it doesnt over heat due to no air flow.. let the exhuast and heater thaw it out... i dont know.. hell i live in texas..haha..
dsmawd350
02-15-2007, 01:51 PM
get some buckets of hot water, it'll probably tun back to ice but it;ll melt down and run off first
2000GTP
02-15-2007, 01:59 PM
Judging from above, you have plenty of options that don't involve spending a couple hundred bucks on a tow charge. :) I would probably start with the hot buckets of water.
wakebordr2006
02-15-2007, 02:04 PM
thanks guys! i'm at college so the buckets of hot water sounds like the best shot for me.
Spllouder
02-15-2007, 07:58 PM
use hot buckets of water and let the car run and warm up you get it out . i had to put hot water on my doors to get them open after 1 inch tick ice on my car from frezzing rain . and hose will work all well just takes longer and refeezes faster .
Greed4Speed
02-15-2007, 09:27 PM
Water, unlike most liquids, expand when frozen. Thats most likely why your car has been lifted.
Depending on how cold it is, the buckets of hot water would work fine. Add some ice melt or rock salt to the water and really go to town. Just don't put the ice melt/salt mix on the car. I'll caution you about putting hot water on your windows though. Use warm water there or you can crack them.
If that doesn't work, steam cleaners aren't that expensive to rent.
JP95ZM6
02-15-2007, 11:42 PM
Not like this:
http://www.youtube.com/watch?v=A3bQ1nHqkHc
T/A-Bob
02-16-2007, 12:21 AM
Get a flexible piece of hose that can withstand some heat. Put one end over a tailpipe. Put the other end under the car where the hot exhaust gas can hit where the ice is. Run the engine for a bit, and it will melt whatever is in the way.
No worries about carrying buckets of hot water, nor of the water freezing again once it gets cold.
fredmr39
02-16-2007, 06:11 AM
good idea.....but I imagine it would be pretty difficult to obtain such hosing on a college campus... also, unless he can get something like that from the engineering dept or something...who wants to pay for hoses when water is cheaper (most likely).
wakebordr2006
02-16-2007, 08:36 AM
thanks again guys. i was actually pulling into a spot, the only one available and i was in a rush to get to class, and i didnt notice that a small wheelbase car or suv was in there before me so i just went for it and only made it half way in. i got it out early this morning though. i just had a friend sit on my rear fender to put help gain traction to the rear wheel that was spinning and it came right out. didnt need the hot water afterall.
nodnarb481
02-16-2007, 10:25 AM
i sat behind my car with a hammer for almost an hour yesterday beating away the ice that was built up behind my tires.. i tried boards, i was afraid to try hot water because it was FREEZING out so it probably would have iced up.. what it eventually came down to was my frustration led me to just floor it in reverse and the car just started sliding in both directions sideways and then just hopped up and over the ice and i took off down the driveway.. dont **** with them V8s ya hear?
xdamagedx
02-16-2007, 03:23 PM
I've got this same problem, I just bought a house and my camaro is chilling next to my moms house.. where it's been all winter. Well, now since I have a 2 car garage it's stuck in a foot deep bank of snow all around it... and nothing in my garage.
