ZL1modified
02-15-2007, 08:42 AM
had came out and i have no clue where it goes... i was under there looking and i just don't see... this would be under the dash beside the steering column...
can someone please help me?
I noticed my hatch cableZL1modified 02-15-2007, 08:42 AM had came out and i have no clue where it goes... i was under there looking and i just don't see... this would be under the dash beside the steering column... can someone please help me? shoebox 02-15-2007, 10:36 AM What the heck is a hatch cable? blackrat 02-15-2007, 11:05 AM are you talking about the yellow button near where the hood release is? that is a common thing to come out if someone is taking out the knee bolster and isnt paying attention. ZL1modified 02-15-2007, 11:23 AM no, not the button... i have a cable pulled out, it looks similar to a throttle cable... it has a white plastic piece on the end... when i pull on it i hear a click in the back (somewhere)... i assume it is the hatch release cable (i dunno, could be wrong)... Terran2k 02-15-2007, 11:26 AM i have a 97 z and the hatch is electronic. shoebox 02-15-2007, 11:35 AM You must be talking about the BTSI cable that connects from the ignition switch to the shifter. There is no hatch cable. ZL1modified 02-15-2007, 11:37 AM You must be talking about the BTSI cable that connects from the ignition switch to the shifter. There is no hatch cable. ok, i'll go with that... i know you know your SH**... where does it go, in detail? shoebox 02-15-2007, 04:05 PM ok, i'll go with that... i know you know your SH**... where does it go, in detail? Sometimes I mix things up :D -it's actually the park/lock cable-not the BTSI. It goes from the ignition switch, down along the floor and arcs around on top of the transmission tunnel to the shifter. Pop off the shift quadrant cover on the console and you will see it. http://shbox.com/trans/park_lock1.jpg ZL1modified 02-15-2007, 04:09 PM your the man! thanks alot Shoebox... | ||
