busterman88
02-14-2007, 12:35 AM
i'm installing some new flowtech headers on a 1987 350 TPI engine. but i notice each side has two connections the new headers dont have anything to connect too. i say i ordered them right but you never know anything can happen. or if thats how it suppose to be tell me what can i do to close lines.
1987IROC350
02-14-2007, 03:44 AM
Is this the part #BIG-11102FLT
These are the only Flowtech showing a proper fit from Summit.
busterman88
02-14-2007, 10:07 PM
well i got the second from last. the ones that cost around $346.
http://performance.thepartsbin.com/basket.php?makeid=5&modelid=30&year=1987&partid=24&brandid=3179
and it doesn't have two connections it has three on each side.
LesPaulGoth
02-15-2007, 12:17 AM
Your stock Y-Pipe only has a two bolt flange, and these headers have 3 bolt flange. If what you ordered was different from what you received, you can call customer service and ask them for the right pair, OR, you could get an aftermarket Y-pipe to fit. Flowtec makes a 3" one with a 3 bolt flange that is decent quality and like $90. I got one for my Camaro and I am happy with it. You should see how restrictive the stock one is anyhow, it resembles this:
http://benelliwang.badassride.com/Engine/images/h_pipe.jpg
If I were you, I'd go for the new pipe if you can afford it. Those headers will see no gain behind a restricted stock system anyhow. You are only as strong as your weakest link, and this is especially true for exhaust.
1987IROC350
02-15-2007, 08:21 AM
Wow! You gotta be kiding me. That is very restricted. My headers came w/Y-pipe. I got these Edelbrock $399 for mine. I'm wondereing if these have a good reputation or what. I didn't do a lot of research when I ordered these. Anyone have them that got a dyno after?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=EDL%2D68723&N=700+4294923429+4294839039+4294908216+4294925008+ 4294908198+115&autoview=sku
http://static.summitracing.com/global/images/prod/large/edl-68723.jpg
87DJP2001
02-15-2007, 08:33 AM
Could be you ordered headers without the A.I.R. fittings which are part of the stock emission. Thats whay you have connections and nothing on the new headers.
1987IROC350
02-15-2007, 09:12 AM
Yea, see the A.I.R. pipes???????
http://im1.shutterfly.com/procserv/47b7dc34b3127cce81c95213653400000016100CcsnLJwzZsa
87DJP2001
02-15-2007, 09:37 AM
Yea and don't get your shor hairs in uproar. :rolleyes: Mayby you bougth some crap.
1987IROC350
02-15-2007, 09:43 AM
Now is that because of the air? I have to pass emmission for another 3 years. They are being installed soon. Isn't a 3" tube a 3" tube? They are going to remove any restrictions in the pipes. :yes:
LesPaulGoth
02-15-2007, 10:18 AM
Ah I gotchya now, thats what you were referring to, the AIR system.
Depending on where you live, you can ditch the AIR and still pass emissions. In NJ all they do is a sniffer, no underhood visual, and I passed all emission numbers with flying colors with my entire system removed.
Definately worth the uncluttering of the engine bay.
