Radio Memory Wire
Don350k
02-13-2007, 10:37 PM
Well, in the F-Body i just bought the radio fried (no doubt due to the hookup) u dont wanna see how that was.
Now theres no power to the radio memory wire (12+ All the time)
I remember working @ Exclusive Co in Wi as a pro audio installer there were fuses on 3rd gens above the GM1 Connector, i dont see any on this one, and all in the box underhood and side dash are good, i cant seem to find any blown anywhere, i was wondering if anyone has found any?
I dont really wanna run a live wire to it from the box, or underhood id like the main to work if ya know what i mean since the cig lighter doesnt seem to work either,
and yes i have checked all fuses in the dash side and underhood, and the connections there
Don
mdacton
02-13-2007, 10:47 PM
you got a bad fuse somewhere
Don350k
02-13-2007, 10:50 PM
Positive there all good, used to install this stuff for a living, if i were @ shop id prolly just run a new wire lol, what i was asking is there any hidden like in 3rd gens?
Don
mdacton
02-13-2007, 10:51 PM
I don't think so....I will look at aldata in the morning
Don350k
02-13-2007, 10:54 PM
Thanks, I miss alldata, why did i get laid-off LOL
Don
95camaroinok
02-13-2007, 10:56 PM
I dont remember which wire I used, mines hooked up to the switch like factory. Do a continuity check between the fuse and the wire to make sure the wires not cut or shorted somewhere. If you still cant get it by tomorrow, I'll pull mine out and check for ya. You might also have a problem with your ignition switch or retained accy mod. I've had problems with mine doing that.
Critter
02-13-2007, 10:59 PM
the fuse is blown on the cd player and cig lighter. if that doesn't work splice into the hazards
95camaroinok
02-13-2007, 11:00 PM
Also there is a hidden Accessory wire under your console. I believe shoebox has the instructions on his site. Its an orange wire thats kinda just tucked into some tape near the front of the console. It has a little tag on it and it jus pulls out of the tape. It is hot all the time.
Don350k
02-14-2007, 05:04 PM
thx, i may have to use that wire under the console, all fuses r still good, sigh, prolly a broken wire and ill b dammed if ill pull the dash for that lol
Thx
Don
95camaroinok
02-20-2007, 12:21 AM
hey Don did ya get your power problems fixed?
Don350k
02-24-2007, 05:26 PM
Nope, al fuses checked out and its to damn cold to trace the wires LOL ill post when i get it fixed
mdacton
02-24-2007, 05:28 PM
whoops, forgot to look in alldata....I will look in there and try to find a diagram
Don350k
02-27-2007, 04:38 PM
thx bud
Don
