slowpoke310
02-12-2007, 04:39 PM
305 tpi changing to 355 (single peice rear main seal)
will the timing cover and oil pan be the same?
oil pan & timing cover ???slowpoke310 02-12-2007, 04:39 PM 305 tpi changing to 355 (single peice rear main seal) will the timing cover and oil pan be the same? Dave89IROC 02-12-2007, 06:42 PM yes, all gen 1 SBCs newer then 86 can use the same oil pans, and as long as its a pre-95 motor, the timing cover too(96+ went to a plastic cover with a crank sensor) | ||
