taylorcrzy
02-11-2007, 09:40 PM
Just wondering which header bolts to order? I have the Pacesetter LT Headers and just need some good bolts. I was looking at these from jegs. The part number is 070-612-1000 and the site is http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_749575_-1_11721
What do you guys think. Is that the right part number? Oh almost forgot my car is a 95 LT1 Trans Am.
Mauiguyy911
02-11-2007, 10:21 PM
Heres the link for the ones that other ppl have told me to use and i also have a '95 LT1 with Pacesetter LT's. Although the ones you listed could work also, not sure:
Stage-8 Locking header bolts:
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_749275_-1_11673
ARP header bolt kit:
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_744888_-1_11673
Sure someone else will chime in on this one though also as im still figuring this out also
martha stewart
02-12-2007, 01:05 AM
I just reused the stock ones. Worked great for me!
MysticTeal95Z28
02-12-2007, 08:31 AM
I have some 3/4" Stage 8 Lockers still new in the box if you would want them. I could probably make you a good deal on them. Let me know.
2000GTP
02-12-2007, 12:14 PM
I would go with 1" Stage 8 lockers personally.
Bayer-Z28
02-12-2007, 09:31 PM
Same here.. I re-tightened/checked them every once in a while. But after about 1000 miles, they've made them selves at home in there. No problems in 2 years.. w/o locktite either.
Stock bolts also depends on the header flange thickness. if it is thicker than stock, you should order the ARP's. -Good brand BTW.. ;)
Mauiguyy911
02-13-2007, 06:14 PM
So, pretty much if you have Pacesetter's than the stock bolts wont work too well since the flange is so thick...What length are the stock header bolts 3/4"?
2000GTP
02-13-2007, 06:19 PM
I believe the stock length bolts are an inch in length, but they also have spacers on them that suck up about a 1/4 inch of the thread.
MysticTeal95Z28
02-13-2007, 06:20 PM
Yeah, that sounds about right. :thumb:
