Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
no injector pulse
Old Feb 11, 2007 | 07:04 PM
lt1tealm6's Avatar
no injector pulse
i rebuild my 94 camaro m6 lt1 and the injector are not firing at all as a new opti and deltec i have lt1 edit i read the codes the only one i get is open fan 1 failure i try using a vat bypass and nothing i try a used pcm from ebay still nothing check wires to the pcm all was good. check schrader valve and push with a key and fuel shot out. put a volt meter to the injector and no pulse. is there any thing that could not be hook up that would cause this. thanks help is needed.
Old Feb 11, 2007 | 09:17 PM
The injector should have 12v on the pink wire with key on and pulsing ground on the other side when they are firing.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
