1LECamaro-2
02-11-2007, 12:43 PM
Need suggestions for easiest oil pan replacement methods.
We just completed an engine swap putting a L98 Hotcam Vette engine in our 1991 Z28-1LE. Now two weeks later while doing shock replacement we dropped the car off of the 3-ton jack before we could get the jack stands in place and ran the jack through the oil pan.:confused: :eek: :eek:
We do not want to pull the entire engine another time!:alert:
Is it possible to pull the pan off simply by removing the motor mounts and Y-pipe and lifting the engine as high as possible with a cherry picker?
We considered supporting the engine and tranny from above and pulling the K-member; however, we aren't very fond of removing 16 old brake line components.
Any help is appreciated.:)
Steve and Zack
1991 Camaro Z28-1LE
Factory 1LE T5 tranny
1LE A/C delete
L98 w/ Stealthram, 1.6 rockers and LT4 Hotcam
Koni SA shocks
900lb/250lb. custom road race springs
36mm/25mm bars
Chromoly adj. panhard bar
6-pt. Autopower cage
1LE brakes
Corbeau seats
Hoosier 315/35/17 A6 tires on 17x11 and 17x9.5 ZR1 rims
Steve and Zack
1991 Camaro Z28-1LE
1LE A/C delete
Koni SA shocks
36mm/25mm bars
1LE brakes
Corbeau seats
