z28camaro095
02-08-2007, 07:14 PM
ok guys i went and bought a 91 z28 and i thought it still had the 305 in it well i got ahold of the guy that did the work on the car. the guy i bought it from wasn't the guy that did the work. so teh motor the trans and the rear end was taken out at 73000 milies and the motor was changed to a 335 stroker motor and the trans and rear end were built it has a custom comp chip. the problem is that it doesn't want to start it turns the motor over and i can get it to start if i spend so time doing it, and it hasn't jumped time. also when i get it started it is overloading. black smoke out the tail pipes so it is running way to rich and i was wondering if thats the cause of it not starting right. i have changed the o2 senser and the MAP senser and before i blow any more money i was wondering if anyone had a good idea. there r 2 more sensers they say control the gas flow and thats the ECM a TPS well guys i need help computer **** isn't my specialty on cars so if u can help me plz do ty for listening.
91Z-28
02-08-2007, 07:24 PM
Was it running ok before you bought it? Or did it just take a dump on you?
Wacky Tower
02-08-2007, 07:32 PM
check the cts or the custom chip has too much start of fuel programed into it
z28camaro095
02-08-2007, 08:28 PM
it was just fine when i bought but 2 days later a buddy noticed that it was overloading. so we have tried to find out whats wrong but nobody around here is a big camaro fan like me so they don't know anythang about them. i thought about putting a rush on my taxes and taling it to a shop but don't want to find out its a 50 dollar part and i end up spending 200 hundred to get it fixed when i can do it. just give some ideas so i can try to narrow it down thx for the input
z28camaro095
02-08-2007, 08:44 PM
what does cts stand for and were is it located b/c i heard that it can cause u to run rich and have trouble starting just a thought any help would be great.
1987IROC350
02-08-2007, 09:31 PM
I think you mean TPS. Throttle position sensor.
http://www.fbodymotorsports.com/inc/sdetail/7550
FNFAL308
02-08-2007, 09:45 PM
Mine did the same thing two days ago. Hard to start and loading. It was the tps.
EDIT: It did this the day after I washed the engine. Not the first time. I tried to keep from getting it wet - but it did get wet.
z28camaro095
02-08-2007, 10:34 PM
so is it the cts or tps? what is the more likly to be my problem :)
Wacky Tower
02-09-2007, 05:02 AM
CTS is coolant temp sensor. If its reading wrong it could be dumping in more fuel than needed. The colder of the temp the more fuel the motor takes to run. So if its reading colder than it really is when the motor is warm it will cause it to run rich. You need to get your hands on a scanner so you can see whats going on.
z28camaro095
02-09-2007, 05:41 AM
ok thx i think i will replacing it tommorrow so hopefully thta is my problem. thx for the knowledge.
1987IROC350
02-09-2007, 05:48 PM
Are you getting a check engine light? I can, as anyone else here can, how to check the codes with a paperclip.
