j0n
02-07-2007, 12:47 PM
PRICE REDUCED - $4500
1995 T/A Vert M6
134k miles on body
~50k miles on engine(stock from throttle body to pan)
134k miles on transmission
~5k miles on rear
~5k miles on clutch(slight upgrade over stock)
Good:
-Power windows, locks, mirrors
-Brand new front bumper cover and passenger fender
-15k miles on new tan convertible top
-K&N FIPK
-Throttle body airfoil
-Trans Am throttle body plate
-Lokar stainless braided dipstick tube
-Pacesetter Longtube "race" headers
-Offroad y-pipe
-Borla w/ open plate
-Spohn tubular LCAs
-Weld-in Relocation brackets
-BMR weld-in subframe connectors
-4.10 rear with 5k miles on rebuild/gears and aluminum dif cover
-New slave
-New clutch fork
-Newish brakes at all 4 corners(replaced within the past year or so)
-Reflective silver decal overlays by Brent Franker
-B&M Ripper Shifter w/ Lou's short stick
-Hurst black classic 6-speed shift knob
-New Taylor OVC 8mm plug wires and NGK TR55 plugs
-MSD coil
-Tuned PCM by Madz28.com
-Inspection good until 10/08
-Raptor Shiftlight
-Power antennae
-12.7 @ 107
Bad:
-Typical daily driver dings, chips, and scratches
-No front swaybar. I have the bar but do not have the brackets for it.
-No air conditioning. I don't have any of the parts to put it back in
-Shocks/Struts and bushings appear to be all original so they could use replacing
-Seats are about a 5 out of 10 due to a few holes and the torn driver's side seat bolster
-AIR pump is gone
-EGR is gone
-No cats
-Missing two of the center a/c duct vents
-Convertible top pump needs fluid and the lines hooked up properly to work
-Highbeams and right turn signal have issues but i will supply a newer steering column which should fix those problems
-ABS light is on(haven't checked it out yet)
-Airbag light is on due to a broken clockspring in the center console. Again i will supply a newer steering column which should fix this.
-Some of the speakers need replacing
Looking to sell asap...asking $7,000 obo
EDIT: price lowered see last post
1995 T/A Vert M6
134k miles on body
~5k miles on rear
Good:
-K&N FIPK
-Offroad y-pipe
-Spohn tubular LCAs
-New slave
-New clutch fork
-MSD coil
-Raptor Shiftlight
-Power antennae
-12.7 @ 107
Bad:
-AIR pump is gone
-EGR is gone
-No cats
