snakeatinZ
02-05-2007, 10:40 PM
What is a good Flexplate for me to go with? How many teeth does it need??? set up in sig.
Steve
Steve
What flex plate???snakeatinZ 02-05-2007, 10:40 PM What is a good Flexplate for me to go with? How many teeth does it need??? set up in sig. Steve mdacton 02-05-2007, 10:53 PM jegs has a descent one 555-60153 if you just want a stock one let me know....other than that you nd a 153 tooth for 1pc. seal 86-up 12SCNDZ 02-06-2007, 01:02 PM I agree...Jegs has an SFI approved plate for less than a stock one costs. Frank CPT snakeatinZ 02-06-2007, 04:37 PM Cool. That is the one I am going to buy. Thanks guys, Steve snakeatinZ 03-06-2007, 02:41 PM How many bolts do I need to buy from GM? I am going with Part # 14088764. Thanks, Steve mdacton 03-06-2007, 04:05 PM what bolts? its cheaper to get the ARP's anyway snakeatinZ 03-06-2007, 04:15 PM what bolts? its cheaper to get the ARP's anyway Flexplate bolts. I searched it and found people are having problems with Arp ones. The head on them is too big and does not fit a socket well??? Steve The Engineer 03-06-2007, 08:33 PM Flexplate bolts. I searched it and found people are having problems with Arp ones. The head on them is too big and does not fit a socket well??? Steve Yes, that is correct. The large 12-point heads on the ARP flex-plate bolts do not allow space for the socket between the crank hub lip. Get a new set of OEM (GM) flex-plate bolts. Also, use a thread locker and make sure the flex-plate isn't powder-coated. WD mdacton 03-06-2007, 11:16 PM ARP came out with new ones that have smaller heads. rskrause 03-07-2007, 06:19 AM You realize that this is not an LT1 specific piece but is generic? If you have stock rotating assy., you can buy a flexplate that is a simple bolt on as it is already balanced against a stock bob weight. If it's for the combo in your sig, which looks like a non-stock setup, it is going to need to be final balanced. You probably already know this, just pointing it out to those reading who think the piece would be a simple bolt-on. Rich snakeatinZ 03-07-2007, 07:17 AM You realize that this is not an LT1 specific piece but is generic? If you have stock rotating assy., you can buy a flexplate that is a simple bolt on as it is already balanced against a stock bob weight. If it's for the combo in your sig, which looks like a non-stock setup, it is going to need to be final balanced. You probably already know this, just pointing it out to those reading who think the piece would be a simple bolt-on. Rich Rich, whenever you have something to say I am all ears. Over the years you have tought me alot about these cars. My motor has a stock crank, with forged Speed Pro pistons. I need the flexplate for the Machine shop. This weekend they are going to get everthing I have to assemble the long block. :D oooh happy day!!!!!! Steve rskrause 03-07-2007, 07:38 AM Rich, whenever you have something to say I am all ears. Over the years you have tought me alot about these cars. My motor has a stock crank, with forged Speed Pro pistons. I need the flexplate for the Machine shop. This weekend they are going to get everthing I have to assemble the long block. :D oooh happy day!!!!!! Steve Great feeling! A "generic" flywheel like that will usually have a large balance weight. The machine shop will balance it against your specific assembly by drilling shallow holes in the weight to remove the necessary amount. Rich | ||
