slowpoke310
02-05-2007, 12:16 PM
hey do rims from a 4th gen fit on 3rd gen???
will z06 18x9.5 18x10.5 with 295
fit a 87 i-roc???
fit a 87 i-roc???
wheel 3rd gen -to- 4th gen???slowpoke310 02-05-2007, 12:16 PM hey do rims from a 4th gen fit on 3rd gen??? will z06 18x9.5 18x10.5 with 295 fit a 87 i-roc??? Duke 02-05-2007, 12:22 PM You need wheel adapters to make them fit. I have 4th gen wheels on my Camaro and had to use 2" spacers front and back. Got them from Skulte Performance. Do a search, I can't remember his URL. krisb410 02-05-2007, 06:54 PM There a ton of them on ebay. I'm switching to a 4th gen rear and gonna use a set of 2in spacers on the front. Purple 92 SS 02-07-2007, 10:29 AM I have a 4th gen rear, and use the Skulte Adapters on the front as well. I too use 18x9 Z06 up front and 18x10.5 in the rear (thats on my 92 RS) slowpoke310 02-13-2007, 12:07 PM thanx guys, my buddy has a 87 iroc who's trying to put the z06's 18x9.5/18x10.5s, having some troubles where can i find those adapters? how much do they run about? hope their not an arm and a leg Angelis83LT 02-13-2007, 12:11 PM thanx guys, my buddy has a 87 iroc who's trying to put the z06's 18x9.5/18x10.5s, having some troubles where can i find those adapters? how much do they run about? hope their not an arm and a leg http://www.skulte.com/product_info.php/cPath/21/products_id/55 There is the link for the 2" adapters. they run $150 a pair. but they are top quality.. and they are different then just a spacer. These actually bolt to your cars lugs.. then you bolt the wheels to the adapter. You will see what i mean when you look at them.. You are using all of the stud instead of just the end like on a spacer. If You get just a spacer that goes in between you run a pretty good risk of breaking off lugs and doing serious damage.. Best thing to do is to just shell out the $300+shipping and do it right. stepuptata 11-07-2007, 07:07 PM putting 4th gen on my stock 92 RS conv. Do I only need the 2" spacers on the front? Or front and rear. I thought just the front only, but just checking. Thanks. krisb410 11-07-2007, 07:14 PM If your using the stock 3rd gen rear, then you will need a spacer/adapter. | ||
