LT1_383
02-04-2007, 11:29 PM
I seem to get bored with cars every two years and this one is no exception. I'm thinking about getting into a new GTO.
I bought this car in March of 05 from a Nissan Dealership in Pennsylvania with 78k miles on it. I’m the second owner and it now has a little over 96k. Since I can’t leave well enough alone I pulled the perfect running motor out last winter with just under 90k miles on it. I ordered up a forged 383 short block from Golen Engine Services out of Connecticut to replace it then sent my heads and intake manifold out to Advanced Induction in North Carolina to have them ported. When both arrived I put it all together and dropped it in. Fired up first shot, just like on TV. It’s been my daily driver since with no issues. It has a bit over 6k miles on it now.
Quick Specs
95 Trans Am
383 LT1
390RWHP @ 6400 and 376ft lbs @ 4200
Best ET of 12.1 @ 114 with a 1.78 60'
4L60E with 3k Stall
3.23 Gears
Front and rear pads have 5-6k miles on them
BFG G-Force TA KDWS Tires have 4-5k on them.
Pair of 255-50-16 ET Streets mounted on matching rims included, at least half tread left
Charcoal gray leather in good shape
T-tops with t-top shades
All factory options
XM Radio
Aftermarket Keyless Entry and Remote start
New Battery 6 months ago
Engine/Transmission Mods
Golen Engine Services 383ci Street/ Strip Shortblock, 4 bolt main block with ARP main studs, Clevite Bearings, Eagle cast crank, Scat 4340 Forged 6” rods with floating pins,
Mahle Forged Pistons. Melling oil pump and hardened drive.
Advanced Induction Street / Strip head package. 180cc Intake runner, 56.4cc combustion chamber. Comp Beehive springs, 2.00” intake 1.55” exhaust valves. Flows 260cfm on the intake and 197cfm on the exhaust side.
Custom grind Camshaft from AI. Mild and VERY streetable (actual specs will be given to serious buyers)
Comp Cams rocker studs, pushrods, guideplates, double roller timing chain and Pro Magnum 1.6:1 Rockers
Advanced Induction ported intake manifold
Racetronix 37# injectors
BBK 58mm Throttle Body
1LE Intake Elbow
Moroso Cold Air Kit
Meizer Electric Water Pump, 160* thermostat
ASP 23% underdrive crank pulley / damper
New GM optispark when motor went in
New GM engine and transmission mounts (tried poly mounts but wasn't pleased)
Taylor Wires with Made for you wire looms
Pacesetter long tube headers w/ emissions bypassed
Off Road Y-pipe and Hooker Cat Back exhaust
3” Cut out
Yank 3000 Stealth Stall Torque Converter
B&M 24000GVRW Transmission Cooler mounted to the AC condenser
Earles Stainless steel braided -6AN lines for the Trans Cooler
Tuning by Jeff Creech at Carolina Auto Masters
Suspension
BMR Weld in Sub-frame connectors
BMR Lower Control Arms
Spohn Strut Tower Brace
BMR 1” lowering Springs
Bilstein HD Shocks and Struts
1LE 32mm front sway bar with Energy suspension bushings
BMR Adjustable Panhard Rod
Brakes
Earles Stainless Steel Brake Lines
Hawks Front Pads
Stereo
Pioneer CD, MP3 player
Sub Thump Stealth Box and Amp Rack
Rockford Fosgate 8guage wiring
Rockford Fosgate P300.2 amplifier
MB Quart 10” sub
XM Satelite Radio - Everything is built in, or hidden behind the dash. Displays through the CD player. The antenna is hidden in the rear spoiler, no wires are visible.
Overall
You'd be hard pressed to find a scratch or a ding on it.
Everything is smooth, no vibrations
Transmission doesn't slip at all, shifts flawlessly
Great daily driver, no cam surge, can't even tell it has a high stall converter
Idles great
The negative
Was in a minor accident last summer, air bags didn't even deploy. Cracked the front bumper and fender up. Everything was replaced with GM parts (have receipts) and the whole front end was repainted by a very reputable shop. I'm a very picky person and was pleased with the work.
The drivers side bolster has the usual wear, although not as bar as many others I've seen.
Drivers floor mat is also worn a little
Rear seat back is separating a little at the seem towards the top, easy repair. Haven't had a chance to get to the upholster yet though.
I have receipts for most every part.
I have over 25k invested. Looking to get $10k
Got any questions or want to arrange a test drive call me or PM me (631)790 7674
Check out my car Domain page for pictures (link below)
Quick Specs
95 Trans Am
383 LT1
4L60E with 3k Stall
3.23 Gears
All factory options
XM Radio
1LE Intake Elbow
Moroso Cold Air Kit
3” Cut out
Suspension
Brakes
Hawks Front Pads
Stereo
MB Quart 10” sub
Overall
Idles great
The negative
