kingman109
02-04-2007, 11:17 PM
Now before reading any further, just want to point out the car is a salvage car which was rebuilt - Between this and the paint thats needed, ill keep the price low, and give you any information you need. I've been around this board a long time, and have documented everything (not to mention can search through my old posts).
So lets begin-
1997 Camaro Z28 -
6 - speed
Ebony interior
Leather
T-top
Engine :
118k on car ( cam/valvetrain installed at 109k)
Comp Cam XE 230/236 112 Cam
Comp Pro Magnum 1.6 RR NSA
Comp 918 Beehive springs
Comp Chromeoly Hardened Pushrods
ARP 7/16" Studs
AFR Guide Plates
(and all new seals, 10 degree locks yadda yadda)
Electronics
MadZ28 Tune
LT4 KM
Dual Speed Fan Switch
Exhuast
SLP Shorty Headers ( Jethot coated)
New Factory Y-pipe with cats ( 3k on it )
SLP Loudmouth (gen1)
Transmission/clutch
T56
Pro 5.0
these are actually being installed tommorow - so brand new
Spec Stage 3 clutch
Spec Steel Flywheel
Intake
K&N FIPK
Trickflow Ceramic coated elbow
Airfoil
Rearend
5k on since install (3k was crosscountry drive)
Motive 4.10s
Auburn Pro Posi
Misc stuff
BMR aluminum fuel rail covers
BMR aluminum Radiator Shroud
BMR alternator fan/pulley
Harlen Shift Light
Misc Parts that have been replaced in past year
Taylor OVC wires
NGK TR5 sparkplugs
New GM waterpump
New GM Opti
New Timing Gears/Chain
New Axle Seals
Misc Bushings/tranny mount
Ignition Coil
!EGR
!AIR pump
!VATTS
!O2's
Just about every seal on the engine....
well i think that covers most of the stuff. so lets get into the cars history.
I purchased the car about 3 years ago, from an F-body salvage yard, with the intent on parting it for an engine swap. Fell in love with the car. It had been in a front end accident 2 years prior which not only damaged the front end but deployed airbags. I spent the summer rebuilding it, with the aid of a local frameshop. We cut and re-welded in a new front clip, and the car past a salvage inspection with flying colors.
I drove the car for 2 years, through college untill last fall when i hit sand on a turn and lost control. Thought i could control the skid but by the time i had her straightend out and was braking, a lightpole came up. I hit at about 5mph in between the bumper support so it crushed in my bumper and chipped the hood.
Instead of paying for bodywork, i decided to cam the engine and focus on performance, and just bolt up primer front end, fender.
With mods listed above, i ran a best time of 12.3 at 116 with nitto drag radials. Car dynoed at sea level 364 horse and 354 torque.
This was last spring. I graduated college and got a job out in boulder CO, where i am currently located. The plan was to rebuild the car again, and go forced induction, but with the weather and high altitude i can no longer keep this as a daily driver. Also with no garage means i cant store her. She currently has the factory rims on with BFG KDW's on all 4 with roughly 5k miles on them. (3k from cross country drive). Still lots of tread. I also have a set of 18 x 9.5 C5 Y2k's in chrome sitting in my basement. The front tires have Eagle F1's and the rears are Nitto 555's. Unfortunately they have curbrash and the chrome is starting to flake.
Given the cars current appearance (cracked hood, primer front bumper, missing foglights, and primer fender), and the salvage title i understand shes gonna be a rough sale. She would however make a great project car, or donor vehicle/track car. Being the person who did almost all the work on the vehicle, i know everything thats been done and would be more than willing to answer any questions / provide pictures or even video.
ill follow up this post, with pictures/video and soon as i get her back from the getting the clutch installed, more recent pictures.
Make me an offer -
So lets begin-
1997 Camaro Z28 -
6 - speed
Ebony interior
Leather
T-top
Engine :
ARP 7/16" Studs
AFR Guide Plates
Electronics
MadZ28 Tune
LT4 KM
Exhuast
Transmission/clutch
T56
Pro 5.0
Spec Stage 3 clutch
Spec Steel Flywheel
Intake
K&N FIPK
Airfoil
Rearend
Motive 4.10s
Auburn Pro Posi
Misc stuff
Harlen Shift Light
Taylor OVC wires
NGK TR5 sparkplugs
New GM waterpump
New GM Opti
New Axle Seals
Ignition Coil
!EGR
!AIR pump
!VATTS
!O2's
Make me an offer -
