spinish
02-04-2007, 10:39 PM
ok, tell me what you know. I have a 1977 camaro with a 10 bolt. My question is did chevy come out with 2 differant kind of yokes for the rear end. On my yoke the part where the u-joint sittes is smooth, there are no little tabs that stick out, and it had "c" clips holding it in. I can't find any thing about this on the internet so i thouht I would ask u guys.
mdacton
02-04-2007, 11:57 PM
what do you want to know? do you have inside retainer snap rings on the shaft and the pinion yoke? 3 5/8 width 1 1/8 cup?
spinish
02-05-2007, 12:09 AM
there arew no snap rings. there were c-clips on the inside of the cups. they were not snap ring. as far as I can find the stock rear ends didn't have c- lips bit little tabs, but mine has c-clips. I want to know if any one else has one like that.
mdacton
02-05-2007, 12:15 AM
well sound like you have the 1310, the one with the tabs on the outside is a 3/4 ton u-joint....i'm not familiar with what came stock in those....the 82-up would use the inside cir-clip
