1991 Z28 350 HSR 3.73 4 wheel disc in Mi $4000
Kado91Z
02-02-2007, 09:09 AM
1991 Z28 Flame Red with silver racing stripes
-350 SBC with Lunati Voodoo cam, Holley Stealth Ram injection
-Hooker Super Comps
-3.73 posi rear with PBR discs
I have many more details but not the time to type it now. E mail me at ZCap91@yahoo.com for a full list of specs. Asking $4000
Kado91Z
02-05-2007, 09:41 AM
bump...
Kado91Z
02-07-2007, 03:17 PM
Ok here's the full deal. The car reads 200k on the odo, but most things have been replaced. Heres the specs.
-Flame red metallic paint with 2 silver racing striped from nose to ass end of the car
-Full 1991 aero GFX kit, no cracks
-Gray interior
-6 point cage welded in
-350 SBC
-DART iron eagle platinum series heads
-Holley Stealth Ram injection with 24 lb/hr injectors, Kirban Billet adjustable fuel pressure regulator, BBK 52mm throttle bdy
-Lunati Voodoo 268 cam and lifter kit
-Harland Sharp 1.6 roller rockers
-Moroso deep sump pan with windage tray and trap door baffle
-new waterpump-new 104 amp 1 wire alternator
-Accel small cap distributor, new MAP sensor, new IAC, TPS sensors
-BLaster 2 coil
-Hooker Super Comp 1 3/4" headers ceramic coated
-Single 3" exhaust, no cats into Hooker Aerochamber 3" muffler
-A/C deleted with 1LE box, blower motor just needs to be spliced in
-Dual electric fans, aluminum radiator
-1LE aluminum driveshaft
-Harwood 2.5" fiberglass bolt on hood
-10 bolt 7.5" rear with 28 spline axles, Auburn POSI, Richmond 3.73 gears, PBR disc brakes with aluminum calipers
-Hand stripped and polished 16" Z28 wheels
-New walbro 255lph fuel pump
-new fuel filter
-700r4 tranny
-2400 stall converter
The body is good, has the usual dents and dings here and there. The DS door has a paint flaw which i can show in pics. Also the rear bumper support needs replaced (typical on third gens). The interior is in good shape, the carpet is just a little dirty in the footwells. The cage could use repainted also. has t-tops that dont leak. runs and drives well. Asking $3500 need it gone! E mail ZCap91@yahoo.com for more info
