1996 Trans Am Ws6 Ram Air; Sell Quick!
96383ws6
02-01-2007, 10:24 AM
for sale: 1996 Trans Am Ws6 Ram Air, Black on Black with Flames. 6 speed, Leather, Pioneer Cd, PW,PM, PL, T-tops, BBK 58mm throttle body, 1.6 roller rockers, ZZ4 hot cam, 10:1 comp. t-rex 255 fuel pump, hooker super comp long tube headers, stainless steel magnaflow muffler with dual polished stainless tips, B&M ripper short shifter, spec stage 3, 6 puck sprung clutch. Intrax 2" drop springs, J&M 1"7/8" red powdercoated trailing arms with poly bushings(no wheel hop), custom built 7/8" fully adjustable aluminum pan hard bar with heim joints. 17x9.5 polished american racing torque thrust II wheels, on all 4 corners, with goodyear eagle Gt II's 275/40 up front and 285/40's out back, limited slip with 4.10 gears. is set up with 2 gauge pillar pod with auto meter phantom series white face boost, and fuel presseure gauges...i was going to supercharge it but then ended up buying a superduty and putting my time and money into that, now the f-250 needs a tranny so as hard as it is it must go, to pay for truck parts.
I will say that it does need 5th and 6th syncro's and a reverse gear, due to the guy who i bought it from had put in the short shifter and had the stops adjusted wrong, so it wasn't getting all the way into the gears i fixed this asap when i bought it but, it was already to late. the only other thing is the stock starter has a little trouble with the higher Comp.ratio, so a higher torque starter would be a nice addition(can find them for around $75 on the net). Any questions call or e-mail for pics.
i paid over $7,500 for the car the exhaust was about $450 the traction and pan hard bars $200 and the clutch was $450, so i have easily $8,600+ in this car, but need to sell quick so i am asking $6,500 o.b.o as is. please feel free to contact; Matt-(616)299-5997.
170mphparachute
02-01-2007, 11:31 AM
dont waste your time, this car is nothing as he states. Wasted my time and money to drive 2 1/2 hours and then he acted like I was the *******. HE states it has a 12 bolt uumm no, it has a stock rear end, he told me it has injectors, nope, stock injectors, then the ****ing car wouldnt start when he tried to start it. Dont waste your ****ing time. Did I mention, I dont even think it has a stroker motor in it. 99% of guys change out the oil pan when they stroke the engines, this car has a stock oil pan.
dre2013
02-01-2007, 06:20 PM
:Owned:
96383ws6
02-02-2007, 03:54 PM
maybe if you read this re-post you will see that stuff you just said is not in there.
170mphparachute
02-02-2007, 04:59 PM
maybe you should think and find out things before you waste someones ****ing time. Your lucky you weren't on my property. You should of offered me gas money or something, after all, it was 100% bull **** on your part.
Umbrae
02-09-2007, 08:37 PM
This is the funniest for sale thread i've ever read! ;)
snakeatinZ
02-09-2007, 09:44 PM
What is so funny about it? Seriously? Chute has every reason to be pissed. A man is only as good as his word. This Matt guy sound like a real tool!
Steve
RedFormula1
02-09-2007, 09:53 PM
Maybe I'm wrong but I thought that LT1's had a 10.25:1 compression ratio stock. 10:1 should be easier on the starter.
