FS: 94 Formula (tampa area)
Tonedef
01-31-2007, 09:16 PM
Ok well I'm selling my formula cause i don't have time for it anymore and I need money so i can pay for my other car......so here it is, It's a 94 Formula, auto. The motor has about 500 miles on it since it was rebuilt.....heres a list of what it's got
(headwork, intake and MAF were done at HPS cylinder heads in Tarpon FL)
-Ported intake manifold
-BBK 58mm throttle body
-30lb SVO injectors
-Stage 3.5 ported heads with vortec valves
-New LT4 valve springs
-crane gold 1.5 rockers
-New Lifters
-New comp cams pushrods
-Comp cams 305 cam .510/.510 lift
-Computer reprogramed by Ion at MadZ28.com
-LT4 Knock Module
-Ported MAF
-K&N Cold air intake
-Pacesetter shorty headers
-Dynomouth exhaust (SLP Loudmouth with a dynomax bullet muffler, 3" slash cut tips))
-New water pump
-New Balencer
-New O2 Sensors
-EGR Blockoff plates
-MSD Blaster coil
-New Plug wires with delco platinum plugs
-New Fan motors
-New oil pump
-New Radiator
-new rod and main bearings
-new piston rings
-New Lunati timing set
-Cap and rotor on opti have been replaced
-energy suspension motor mounts
-rebuilt 700r4 tranny W/ B&M 2500 stall (also comes with the 4l60 that came from the car , Works fine)
-TCI 700R4 Torque converter Lock-up Kit (not installed)
-3.42 rearend
-Adjustable Panhard bar
-Rotors and pads have less then 5k miles on them
-Struts and shocks have less then 5k miles on them
-New ground control front coil overs
-Camaro SS rear Springs
-Y2K Vette wheels
-Energy suspension complete polyurethane busing set (Not installed)
-New tie rod ends (not installed)
-Brand new Falken tires 275-40-ZR17 (not installed)
-Leather interior from a 97 TA
-steering wheel and airbag from a 99 TA
-New Autometer Oil Pressure and water temp gauges
-Rear tail light blackouts
Also comes with some spare parts
-set of firebird tail lights
-Good 4l60 tranny
-spare set of tail light wiring
-some spare interior pieces
The body does need some work, the rear bumper has a crack in it, and the rear quarter has a small dent....The pain on the car is original so it could use a fresh coat.
I'm looking to get $6200 OBO, and I'm not parting the car out so please don't ask. As far as lowballing me....go ahead, at least it's a start we can work from there :D .....
If you have any questions pm me or email me at Tonedef7279@msn.com
Lots of Pictures can be seen at www.boostboards.com/vdub
http://boostboards.com/vdub/main.php/d/506-2/100_2142.JPG
http://boostboards.com/vdub/main.php/d/655-2/100_1653.JPG
