View Poll Results: Best overall FI spark plug
NGK TR55 (stock number 3951)
5.88%
NGK TR55IX (stock number 7164)
0%
Autolite 764
0%
Champion RS14YC6 (stock number 13)
0%
Denso IT-16 (stock number 5325)
0%
NGK TR6 (stock number 4177) (One step colder)
64.71%
NGK TR6IX (stock number 3689) (One step colder)
0%
Autolite 103 (One step colder)
23.53%
Denso IT-20 (stock number 5326) (One step colder)
0%
NGK BR7EF (stock number 3346) (Two steps colder)
5.88%
NGK TR7IX (stock number 3690) (Two steps colder)
0%
Autolite AR94 (Two steps colder)
0%
Denso IT22 (stock number 5327) (Two steps colder)
0%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Best plugs with Blowers?
Old Jan 24, 2007 | 10:46 PM
VK's Avatar
VK
Doesn't really matter if its stock or built, really doesn't even matter if its for an LT1 or even a GM car really...
Flat out whats the best plugs to use... power vs dependability of course is going to vary greatly.. but that is all a matter of style really
Old Jan 25, 2007 | 05:23 AM
SMOKNZ's Avatar
I ran Autolight 103's in my AFR heads till I figured out I'm supposed to be using a gasketed plug, not a taper seat. I now use the NGK BPR8ES plug. I didn't have a problem with either one.
Old Jan 25, 2007 | 09:31 AM
OBE1 95Z28's Avatar
It's my understanding that the Autolite 103 is 2 steps colder and the Autolite 104 is 1 step colder. I've run both these plugs with good results.
Old Jan 25, 2007 | 09:51 AM
VK's Avatar
VK
I would guess that using a iridium tip plug wouldn't be a good idea with FI? Kind of like you don't want to run certain kinds of plugs with the spray because it could melt the tip... if I'm understanding plugs correctly.
Old Jan 25, 2007 | 11:22 AM
mzgp5x's Avatar
I've run tr5 & tr6, now, a zex plug. The zex plug has not fowled. I've since leaned out the WOT AFR/ and, low speed closed loop AFR. I purchased a spare set.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
SpeedJunkee
Jun 6, 2015 04:27 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
