Which scanner???
Old Jan 22, 2007 | 04:29 PM
gameparadise's Avatar
Which scanner???
Hello everyone. I have a 1994 Z28 and am trying to find out which scanner is a good one to buy so I can see for myself what is wrong instead of taking it to the shop for answers. I live in Europe and choice of shops are very limited. I just had my Opti (yeah I know about all the bad things mentioned about the Opti) changed Nov 2005. Last month I found out it needs to be changed again. I find it hard to believe after 13 months. So before I pay someone to do this I just need to verify it really is the Opti. Anyone know which scanner I need? Thanks!! My car at: http://www.camaro.fiberworld.nl
Old Jan 22, 2007 | 09:10 PM
moparman's Avatar
You need an OBDI scan tool. Are Actron and Autoxray available where you live?
Old Jan 22, 2007 | 09:37 PM
VinceTrifecta's Avatar
That's a beautiful car!
Why do they say you need a new Opti?
Old Jan 22, 2007 | 10:25 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
If you have a laptop, there is free software available, FreeScan maybe. All that's necessary is a cable. Do a search. It's been posted fairly recently. If you can't find it, I'll help. I've never used it, but I'm considering it. All I need is a laptop, the software and the adaptor cable.
Old Jan 25, 2007 | 03:01 PM
I am not sure yet. If not then I can order it from the US with my military mail box. But even if it is here, it will probably be double the price in the US. I just did a search on the internet for pages in the Netherlands. Nothing. Thanks for the info. I wasnt sure if it was an ODBI or ODBII. How could you tell which one it needs?
Old Jan 25, 2007 | 03:03 PM
Up to 1995, they are OBD1, 1996 and newer is OBD2.
Old Jan 25, 2007 | 03:08 PM
THanks!! I dont know why they say that. I was not there when they tested the car. I am not even sure if they have the right software and scanner to get a proper reading from the error. I need a second opinion. The car starts hard like its not getting fuel or spark. Then eventually it starts. The fans (radiator it sounds like) are running fast also and the service engine light is on. While on the highway recently, I tried to pick up speed a little faster to pass a car and the engine sounded like it knocked. So fuel or spark? I dont know. Any ideas?
Old Jan 25, 2007 | 03:16 PM
That sounds like a fried PCM. The LT1 PCM, if it gets corrupted will turn the fans on high speed without the engine running and the check engine light will be on. It will also run poorly because it is running in open loop mode at this point.
Old Jan 25, 2007 | 03:28 PM
Hi Bill, I am interested in the software. I have a laptop, so only need the software and cable. Its possible to even build the cable if I have a schematic of the pin layout. Or if its possible to buy it, then I would buy it. I just did a search for the software and on this site http://www.aldlcable.com/ there is alot of information. I will try this first. I have to buy a cable after verifying if its a 12 pin or 16 pin. Will check it tomorrow. Has your car really been sitting for 6 years?
Old Jan 25, 2007 | 03:32 PM
Could be but I dont remember if the fans came on before I started it. I dont think so. Will the scanner say this if that is the problem? Any idea what a PCM costs? I will start it again tomorrow to see what happens. Right now its 10:30 pm here in the Netherlands. Time for bed. Early day tomorrow.
Old Jan 25, 2007 | 11:25 PM
If the PCM is corrupted this way, you will not get any response from vehicle through the OBD1 connector. If you connect a scan-tool it will say "no response from vehicle" or something similar to this.
You can find used PCMs for $50-$100.
Old Feb 13, 2007 | 02:46 PM
Hi Bill, I bought the cable from the site I told you about. I also downloaded the software from TTS Datamaster. Its taken some time to arrange this so I hope it works. Tomorrow I will connect it to the laptop to see what it does. Wish me luck.
Old Feb 18, 2007 | 01:43 PM
Hi Vgeglia, I bought the cable and connected it to the laptop using the TTS datamaster software, and it connected and now I have the information on my laptop from this software. So is this good enough to rule out the PCM if this worked?
Nayr
Mar 3, 2023 08:34 PM
plattted
9
Sep 20, 2015 11:23 AM
98-LS1Z28
Sep 8, 2015 03:12 PM
z28cam1993
Jun 15, 2015 07:32 AM
aj2494
Mar 12, 2015 10:17 PM
