(LT1) MAC mids and oil cooler
SnakeOiler
01-22-2007, 08:30 AM
Yes, there are lots of threads about MAC mids, but I can't find any that talk about interference with the stock oil cooler.
Has anybody run into this problem? I am mocking up everything on my engine stand and I already have made some O2 extensions for these pipes. How do I get around the cooler pipe interference? Just don't use it?
Looks like even if I don't use the cooler, it's just going to defeat the purpose of the cooler anyway, because it is so close to the coolant pipes.
Comments, thoughts?
Gripenfelter
01-22-2007, 10:30 AM
Never had a problem with the piping on the 95s I worked on. You can also just remove the oil cooler too. They can get clogged up with engine assembly lube and can starve your motor of oil.
BUBBA
01-22-2007, 10:41 AM
DX the cooler. JMHO:cool:
Brent94Z
01-22-2007, 10:45 AM
I had Mac mid lengths and the oil cooler on my 94. No problems...
http://www.bfranker.badz28.com/fbody/exh-0665_IMG.JPG
SnakeOiler
01-23-2007, 11:35 PM
Well, now that I actually had time to bolt the cooler and pipes on, I see that there is no interference. But, the exhaust flange is close to the pipes. Hopefully, I'll be bolting the engine back in the car this Saturday.
Z95m6
01-26-2007, 10:09 PM
I would just ditch the cooler like a few others have mentioned. It'll help get the oil filter farther away from the header and some people gain oil pressure out of the deal too. I'm glad i removed mine. It made it so much easier when i replaced my oil pan gasket on my Z.
