Mac Header Catalytic Converter Options
Steve0
01-19-2007, 09:21 PM
I am looking for a 3 inch converter to install on my Z28. I have Mac headers which are flanged so I also need to purchase a set of 3 inch flanges to weld onto the cat. I was looking at a few options on ebay.
1.
http://cgi.ebay.com/ebaymotors/3-Catalytic-Converter-High-Flow-Stainless-Steel_W0QQcmdZViewItemQQcategoryZ33629QQihZ003QQit emZ130068538757QQrdZ1
2.
http://cgi.ebay.com/ebaymotors/3-Magnaflow-Carsound-Catalytic-Cat-Converter_W0QQitemZ140076525383QQihZ004QQcategoryZ 33629QQrdZ1QQcmdZViewItem
Any perferences of one over the other? Also, anyone know of a cheap place to get a set of 3 inch, 2 bolt flanges?
Z95m6
01-20-2007, 02:42 PM
It sure looks like to me, that the first cat would give you less ground clearance. I'm pretty sure if you hit your cat on a bump you're going to crush it and knock loose the guts of the cat.
12SCNDZ
01-20-2007, 11:13 PM
I used a Catco universal cat. my Off Road Pipe has my cut-out welded in it, and it's the same length and flanges as my cat. It only takes about 20 minutes to swap to the cat so I can run it through emissions.
My converter more resembles the second link you posted. Just make sure your rear flange has some provisions for the mounting bracket, or the exhaust will sag.
Frank
Steve0
01-21-2007, 09:50 AM
After more searching I finally found what I was looking for. I'll post the answers here just incase anyone else happens to ask the same question in the future.
http://web.camaross.com/forums/showthread.php?t=309235
http://www.camaross.com/forums/showthread.php?t=238539
http://www.drgas.com/store/product.php?productid=21&cat=14&page=1
