off the wall question about turbos
FireChicken1995
01-16-2007, 11:57 AM
ok so i kinda jacked this turbo from one of our old strait 6 diesels engines that runs a generator.... i was woundering how do i measure it to tell what size it is? its a garrett the cold A/R is .60 and the exhaust A/R is .69. there is a marking on the cold side "m-24". the im planning on turning this into a turbine engine while over here. i have nothing better to do....... im sure this will get moved to a differnt place but at least a few people will see it and be able to tell me how to measure this lil turbo.
RealQuick
01-16-2007, 03:11 PM
Take the compressor cover off and measure the compressor wheel's inducer (the smallest diameter of the wheel that would be closest to the inlet of the compressor housing).
Example: a Garrett GT42-02. The compressor inducer can either be 74mm or 76mm and the exducer is 102mm. So if you got the turbo that has the 74mm inducer, its consider a T74 or 74mm.
Read this: http://www.forcedinductions.com/help.htm
FireChicken1995
01-17-2007, 12:11 AM
cool thanks man
