Blue89Bird
01-14-2007, 07:57 PM
Just curious, I'm running a very moderate amp, it's like 100x2 and only powering some door speakers. I ran out of 4 gauge wire, but do have some 8 gauge lying around.
Is this going to hurt anything? I know ideally you should use the same gauge ground as you do power, but for such a low power amp, is this going to hurt anything?
LS1 RULZ
01-15-2007, 06:46 AM
There are 2 things to consider when running your power cables. One is how much current will it be carrying and two, how long a run it will be. For a run from the battery to the back of your car 4awg is plenty big enough in most cases. Unless you are running a ground cable all the way back to the battery there is no reason to use 4awg cable for the ground run. Most grounds are only a few feets from where the amps are mounted. Since the run is so much shorter 8awg cable is fine.
Blue89Bird
01-15-2007, 05:09 PM
while the power wire runs the length of the vehicle, the ground is only about 2 ft long. Thanks, I don't have to worry about burning my car down anymore.
Now I just need to get my subthump amp rack so I can tidy this all up, it looks like hell right now
valter
01-16-2007, 09:09 AM
There aren't many 100x2 amps you can stick 4 gauge into :D Anyway, short 8 gauge will work fine with long 4 gauge using much more hungry amps.
