tonyss1
11-19-2002, 08:15 PM
Anyone know the procedure to mearsure for push rod length if your going from a standard roller rocker
to a shaft mounted set.
measuring push rod lengthtonyss1 11-19-2002, 08:15 PM Anyone know the procedure to mearsure for push rod length if your going from a standard roller rocker to a shaft mounted set. Mindgame 11-19-2002, 09:23 PM Most of the shaft systems come with a setup kit... have only used Jesel and Crower so I don't know about the others. Anyways, you need to shim the rocker stands til the setup 'rocker' sits at the crest of the 'setup bar'. Then you shim til the top of the valve stem is even with the gap in the setup rocker... just use a straight-edge. From there you assemble and decide on the proper pushrod length. -Mindgame 96ltz 11-19-2002, 10:00 PM http://www.compcams.com/information/Products/Pushrods/ tonyss1 11-19-2002, 10:19 PM 96ltz........Excellent Thanks;) | ||
