how much boost?
nickp
01-11-2007, 03:04 AM
I have a forged 383 with 11.5 to 1 comp. ratio. If I went with an intercooled procharger kit, how much boost could I run with my pistons?
TransAm396
01-11-2007, 03:35 AM
3-4?? compression is way to high.
Kraest
01-12-2007, 12:11 PM
None.
Change the heads, then run as much as you want :)
Kredz28
01-12-2007, 12:36 PM
Kraest is right..boosting 11.5:1 wont land you the #'s you might be looking for...3-4 lbs woudnt be worth your time or money. Get that CR down to a safe level or stick with the bottle
CALL911
01-15-2007, 06:49 PM
Agree with above posts. Supercharging is expensive, and a waste of money IMO if all you can run is low amounts of boost.
Change the CR, and let the good times roll.
