Need an 93-02 Fbody with an aftermarket stereo to help me test a sub
sleeperZ96BT
01-10-2007, 07:58 PM
Long story short, I am doing a test on an Elemental Designs sub and it will be coming in a stealthbox so I figure the best test would be done in an Fbody. I am also hoping to find an amp (I have one if yours is too much or little power) that will produce 500wrms at 4 ohms.
Let me know if anyone is willing to help out! It'd be next weekend to test it if possible.
Thanks,
Brian
95LT1conv
01-11-2007, 07:18 AM
are you getting a driver or pass. side box? only reason i ask, i because i have a convertible. let me know, i may be able to help. i have a fosgate 500 watt the i power (2) 12" he2's with so it should be enough to test yours.
TedH
01-11-2007, 08:34 AM
If it doesn't have to be an f-body, I have two cars with aftermarket stereos in them... The better one is a 2000 Bonneville. The other is a Chrysler Sebring.
sleeperZ96BT
01-11-2007, 09:05 AM
It doesn't have to be an Fbody, but since it was a Stealthbox I figured what the heck. I would imagine it is a passenger side box, but haven't seen it yet (it is on it's way). I am going to try it in my Monte possibly, but wanted to try it in an Fbody as well.
I'll keep you guys posted; thanks for the offers to help!
My84Z
01-11-2007, 02:49 PM
If I had a stereo and amp I would help you Bri but umm I got a monsoon lol
sleeperZ96BT
01-11-2007, 03:17 PM
Thanks bro, as always! ;)
xstoyz
01-11-2007, 03:39 PM
I would be happy to let you use my 97Z but im in RI im just over the Fall River MA line so if its worth it for you to make the drive.... Let me know.
I have an aftermarket headunit that is set up to run subs but nothing is in the area where the stealthbox would sit.
Ed
sleeperZ96BT
01-11-2007, 04:06 PM
So do you have an amp and or wiring already run?
xstoyz
01-11-2007, 06:53 PM
It currently has 2 amps w/ full wiring but neither are close to 500w but it would be easy to disconnect and attach your amp.
sleeperZ96BT
01-11-2007, 07:10 PM
Sweet-I may have to take you up on this, thanks!
PM sent!
Brian
