Lt1 vs LS1 alignment spec question
Style
01-10-2007, 04:32 AM
After I did my LS1 brake conversion and got it aligned, the caster is out of spec left and right (pos). Are the caster specifications different on an LS1 vs an LT1?
multicar
01-10-2007, 03:34 PM
I thought the LT1 and LS1s had the same spec, except for the early 4th gen f-bods that had less caster(3.5 instead of 5). Mine set at +4caster both sides, -0.5camber both sides and 1/32toe-in. The spec calls for +5caster but the steering wheel is easier to turn with 4 and I can't feel any difference in direction stability.
What did your specs show?
Doug
