TransAm396
01-09-2007, 07:12 PM
Ok here it goes..I have a bunch of questions that need answers. =)
My setup is prety much done. Its a 355 with trickflow 62cc heads and a cc305 cam spinning the engine to 6k(rev limiter set to 6200).I have a MP70 with a .96a/r and im using the PTK gen2 hotside with my own cold side(obx 12x24x4 with the LS1 front end conversion) Im going to be running 10psi and spraying meth. Hoping to make around 550rwhp on 10psi...safely. The car is a 6 speed.
1. What size oil feed and return lines do I need and where can I get them..price?
2.Am I going to need to run a restrictor in the feedline for this turbo?(MP70)
3.Where am I going to have to tap my oilpan for the return and where do I get a source of oil from?(I already have the pan off the engine so its easier to do...)
3.What injectors/fuel pump do I need for 10psi?(ill be using water inj.)
4.Should I get an aeromotive AFPR or can I use my stock one?
5.Fans??? I plan on tilting the radiator straight up so I can probably fit something a little bigger in there...well thats all I can think of for now...
