Low trac and the brakes
madlt1
01-09-2007, 11:18 AM
I was coming to a stop and my low trac light came on and my breaks went to the floor. Some times if its just setting and ideling the light flickers and the engine tries to die. can any body help
bombebomb
01-09-2007, 11:20 AM
Well since were on the topic I also have a question, I have a 94z, from what I know it does not have traction control, yet the light comes on from time to time. Is this normal?
transAMdriv3r
01-09-2007, 12:40 PM
check your abs sensors
jhthornley
01-09-2007, 12:48 PM
I had this, and cleaned my ABS sensor on top of the rear diff.
Good to go now.
JT
madlt1
01-09-2007, 12:58 PM
ok thanks i will try that
2000GTP
01-09-2007, 01:07 PM
I would also check the ground and positive blocks on the passenger side by the battery. The terminals can really get rusted and corroded and cause some electrical gremlins. You also meant the brake pedal went to the floor? Did it regain pressure immediately afterwards, did you pump the pedal a few times, does the problem only show up when the dash indicators come on?
Injuneer
01-09-2007, 02:20 PM
Generally not a good idea to highjack someone else's thread. Traction control was not available in 1994 models. When your ABS activates, the "LOW TRAC" light will come on.
Topic needs to be in the correct forum..... moving.
madlt1
01-09-2007, 06:42 PM
sometimes it regains presure and yes it only does it when the light comes on
hawk29
01-10-2007, 10:03 AM
I also had this problem i cleaned all the abs connections and rear sensor but it still had the problem i then put dielectric silicone on all the connection and havn't had the problem for 2-3 years.
