BrokeMofugga
01-08-2007, 08:33 AM
The security light on my 93 z28 stays on even while its running:confused: .what would cause this,and how would i fix it?Thanks in advance for any help.
Why Is The Security Light On??BrokeMofugga 01-08-2007, 08:33 AM The security light on my 93 z28 stays on even while its running:confused: .what would cause this,and how would i fix it?Thanks in advance for any help. WS6NIGHTMARE 01-08-2007, 05:06 PM Its going to be something with the VATS system. 2001NBMZ28 01-08-2007, 05:16 PM http://shbox.com/1/pass_key.html gtman316 01-08-2007, 10:05 PM The resistor on your key is probably wore down and you'll probably need to get a new key. BrokeMofugga 01-08-2007, 10:29 PM The resistor on your key is probably wore down and you'll probably need to get a new key. Do i have to worry about this anytime soon.like as in making the car not start?because right now it starts and runs.its just that the light stays on.And also were do i get new keys from? Klypto 01-08-2007, 10:30 PM mine just satretd to come on randomly the other day, happened 2x. wont start when its one. but wait a few min it would work... cory reamo04 01-08-2007, 10:44 PM Do i have to worry about this anytime soon.like as in making the car not start?because right now it starts and runs.its just that the light stays on.And also were do i get new keys from? your local GM dealer should be able to supply you with one. I believe they are kinda pricey though Gun5 01-08-2007, 11:41 PM it's not pricey at all to get a new key find out what code u have .. there is a site that lists what ohm goes to what code.. go here order your key $14 http://www.ecklerscamaro.com/product.asp?pf%5Fid=735081&dept%5Fid=1722 bring it to a key cutting place and get it cut... no $150 for a new key Craddock 01-09-2007, 12:24 AM Mine does this if you don't push the key in all the way. Gun5 01-09-2007, 12:35 AM i can ride around all day with my security light on i figure its my key car still turns on and such gtman316 01-09-2007, 06:42 PM Do i have to worry about this anytime soon.like as in making the car not start?because right now it starts and runs.its just that the light stays on.And also were do i get new keys from? I had a Monte Carlo that I drove for over two years with this light on. Never had any problems. Dave89IROC 01-09-2007, 07:12 PM to be safe that it will keep starting, unplug the connector for VATS under the steering column, as long is that is open(since you are in failsafe) it will keep starting BrokeMofugga 01-09-2007, 07:15 PM Cool thanks for all the help,im just glad its nonthing major ill have to worry about :D Thanks everyone, 94_PatriotRed_Z 01-09-2007, 09:47 PM to be safe that it will keep starting, unplug the connector for VATS under the steering column, as long is that is open(since you are in failsafe) it will keep starting How do I unplug that? My light comes on from time to time and it is a pia ti wait 3 mins every time it comes on shoebox 01-09-2007, 10:41 PM How do I unplug that? My light comes on from time to time and it is a pia ti wait 3 mins every time it comes on VATS connector shown in this pic (http://shbox.com/1/air_bag_disc_2.jpg). Dave89IROC 01-10-2007, 01:32 AM How do I unplug that? My light comes on from time to time and it is a pia ti wait 3 mins every time it comes on you can use the plug trick as well, start the car, then unplug the connector, then it will keep starting as long as the resistance is lost after the car is running, it will keep starting | ||
