CALL911
01-07-2007, 08:43 PM
I currently have a 95 Z with the stock PCM (single bar map sensor). From what I understand if I were to upgrade to a 2 bar map sensor, it would be easier for my dyno tuner to re-tune my supercharged Z in my sig, plus, it would probably run better. I am aware that ultimatly a complete FAST system would be ideal, but don't really want to spend the $ involved with that.
My question is, what exactly is involved with switching to a 2 bar map sensor? I am not even sure where it is located in my car. Can I just go to GM and order one for $40?, and then install it right before I have my car dyno tuned?
VinceTrifecta
01-07-2007, 09:49 PM
The MAP sensor on the LT1 is on the top of the intake manifold. It's a small black rectanglar piece bolted to the intake and has a 3 wire connector.
Yes, all you need to do is swap the MAP sensor with a 2bar unit (are those available at GM?) But, your dyno shop must know how to do 2bar PCM programs, also.
CALL911
01-07-2007, 10:10 PM
I'm sure they do, but I'll inquire with my tuner tomarrow. So, switching the little black rectangular piece is all that is needed past tuning??
From what I understand they are available through GM for like $40. Does anyone have any more info on this as well?
VinceTrifecta
01-08-2007, 01:54 AM
I know you can buy aftermarket 2bar MAP sensors. I noticed in the most recent Summit catalog that MSD offers them. I suppose the factory might have used them in factory-supercharged vehicles.
Sweetred95ta
01-09-2007, 01:52 AM
I've heard of a lot of people trying to tune those and not being able to figure it out. It's not as easy as it sounds to tune.
CALL911
01-09-2007, 09:13 AM
And after I talked to my tuner, he concerred with Sweetred95ta's thoughts. Looks like I'll be staying where I am.
