Need help with switching from a 1 bar map sensor to a 2 bar...
CALL911
01-07-2007, 04:20 PM
I currently have a 95 Z with the stock PCM (single bar map sensor). From what I understand if I were to upgrade to a 2 bar map sensor, it would be easier for my dyno tuner to re-tune my supercharged Z in my sig, plus, it would probably run better. I am aware that ultimatly a complete FAST system would be ideal, but don't really want to spend the $ involved with that.
My question is, what exactly is involved with switching to a 2 bar map sensor? I am not even sure where it is located in my car. Can I just go to GM and order one for $40?, and then install it right before I have my car dyno tuned?
Schurters LT1
01-07-2007, 05:02 PM
DOn't spend the time doing the 2 bar, you will pull your hair out.....keep adjusting the PE tables...
CALL911
01-07-2007, 08:18 PM
What all is involved? I am not doing the tuning, and I know that 2 and especially 3 bar map sensors have a much wider spectrum available to tune them, and as a consequence, will probably be able to have a better tune on the car.
Why should I stay away??
john35thss
01-11-2007, 06:32 AM
Superchargers are linear in the way they make boost, eg at a certain rpm your boost will always be the same if belt slip is not an issue.
You can tune a supercharged lt with stock map I have 3 cars in my circle of friends that I tune and fine tune. All 3 run like stock cars at part throttle, my car has passed an e test.
Its in the details, pe tables, kpa tables and constant tables.
John
CALL911
01-11-2007, 08:07 AM
John
After talking it over with my tuner, he told me pretty much exactly what you did. Therefore, I'll be leaving it as is.
Thanks for all the input though!
