Schurters LT1
01-06-2007, 12:56 AM
Hey Guys,
not to sure on what gear i should put in the car ??
Car is an M6
28" tire
3800lbs with me in it
close to 700rwhp
7000rpm
i am thinking 3:73
i think the car should go close to 140mpr in the 1/4
rskrause
01-06-2007, 09:02 AM
It makes peak power at 7,000rpm? If so, 3.73 would be good.
Rich
Schurters LT1
01-06-2007, 10:13 AM
Rich
I am not sure where peak power is, on the dyno i stopped at 6500rpm and it was still going north
I was going to try and take it to 7000rpm if it is still making power
CALL911
01-06-2007, 06:23 PM
If you have good drag suspension and you hook well, I say go with the 3.73's.
If you spin all the way through 3rd, go with some 3.42's.
rskrause
01-06-2007, 07:13 PM
You need to estimate your trap speed and pick a gear to cross the line a couple of hundred rpm over the peak power. This typically produces the quickest/fastest times.
Rich
john35thss
01-08-2007, 08:40 PM
Running almost mid 130's with 3.73 and 26 inch tire. if I had a 28 would run 3.9.
John
