tx77015ls1
01-05-2007, 05:18 PM
This rattle happens when the car is driving with foot on the gas and off the gas. It only goes away when the brake is pressed. I think it is comming from the passenger side front.
Any Ideas what it could be? It seems to be getting worse.
Thanks, Jason
__________________
2001NBMZ28
01-05-2007, 05:43 PM
Noises can be hard to find. Is it constant or only when going over imperfections in the road? You'll have to get under the car with a rubber malet and hit everything in sight trying to duplicate it. From your description I'd look real close at the RF caliper/bolts/etc.
2000GTP
01-05-2007, 05:55 PM
The only way you are going to know is by getting under there and inspecting the everything, motor,suspension,chassis, and brakes. It may turn out to be an easy fix, maybe a piece of road debris got caught in there somewhere.
Dave89IROC
01-05-2007, 06:20 PM
since it goes away when you press the brake, check to see if the caliper/slide pins are tight
scottso
01-18-2007, 03:00 PM
Here's a longshot - I had that for about 6 months when I bought my car (used) before I finally got around to really checking on it. Turns out that one bolt was missing from a front caliper. I can't imagine it worked its way out to the point that it completely vacated the scene - (guess it was the last guy that did a brake job), but it's worth verifying I guess!
italianbaabay
01-19-2007, 03:43 PM
my camaro did the same thing, with a rattle coming from the front passenger side it seemed like, and when i would brake it would go away a little. My rattle happened to be my catalytic converter, something was loose on it. If it is the cat fix it ASAP! i took mine out and put straight piping in the meantime while i get a new one.
_Italian baby :) _
