Rebuilt engine/trans/rear perfect for swap
Old Dec 30, 2006 | 05:05 PM
familytruckster's Avatar
Post Rebuilt engine/trans/rear perfect for swap
Because my job relocated me to DFW Texas, I'm offering up my wagon for sale. I turned it into my race car that I drove 20 miles highway to the track, raced, and drove home. It still has a full interior but no cats, front and rear bumper supports have been removed. This drivetrain is perfect into an older vehicle or should pass emmissions with the addition of some of the original equipment.
You can see pics here:
http://www.cardomain.com/ride/2474119
Below is a list of the good stuff:
LT1 383 with approx 500 miles
Cast Scat stroker crank
Scat forged H-beam rods
SRP forged flat-top pistons
Total Seal rings gapped for 150 HP nitrous
Std volume high pressure oil pump
Ported aluminum heads
2.00/1.55 stainless valves
CM 612 springs
Aluminum roller rockers
230/236 XE Comp Cam
Cloyes double roller timing chain
New Optispark
MSD Coil
MSD 8MM Wires
NGK Plugs
Mezzire water pump
S&B air filter
3.5" MAF
BBK 58mm throttle body
Ported intake manifold
SVO 30lb injectors
Walbro 255 fuel pump
Transmission with about 5 miles
Edge 3200 converter
Beast shell
Billet Servo
Kevlar clutches/band
Street/Strip firmness
Rebalanced DS with HD U-joints
DS loop
3.73 National Drivetrain Gears
Eaton 400# posi
IC CA relocation brackets
Sedan springs
Air Bags
Manual Steering
No ABS, A/C
Front springs cut to lower 1"
Long wheel studs F/R
Bryan Herter program
AKM Cable
IBM Thinkpad Laptop
Looking for $3,750 for the wagon including the computer.
It's best to email me at othercrap05@yahoo.com
feistersLs1
Mar 12, 2015 12:49 PM
skittlez87
Dec 29, 2014 03:23 PM
