Alex94TAGT
12-28-2006, 10:19 PM
My manuals are not located in the same city, so I'm in need of online help:
-I was under the impression that, when the key is turned to the ON position, the fuel pump primes AND the injectors fire several seconds-worth of fuel for initial startup. Is this correct?
-Or, do the injectors only fire while cranking, in conjunction with the optispark signals?
-(Or perhaps both above statements are true?)
It's a 1994 OBD1 LT1 TA. I'll post more info if deemed necessary, but this is a pretty generic question.
(Datamaster shows 0% DC while cranking, which I assumed to be normal. Physical inspection while turning key 'ON' produces no fuel out of the injectors, which I assume is not normal, so I'm a little SOL for the time being.)
