Tim 97Z
12-28-2006, 02:49 PM
My 97 with a McLoed Street Twin has been in storage for about 4 months. When I went to start it, ther was no clutch pressure at all. The clutch will not disengage and the pedal is completely limp.
Any suggestions?
Tim
97Camaro007
12-28-2006, 03:39 PM
Slave/Master Cylinder is what I would check first. Does it have fluid? Also see if your pedal is still hooked to the cylinder under the steering wheel.
Bandit 1
12-28-2006, 05:46 PM
did it leak any fluid? sounds like it developed some air in the system.
Tim 97Z
12-28-2006, 07:00 PM
Nope no signs of leakage.
97Camaro007
12-29-2006, 09:07 AM
It's going to be something to do with your Slave/Master cylinder. It's what creates the pressure on your pedal. If your pedal has no pressure it has to be faulty or disconnected. Make sure it's connected properly on both ends and if it is.. then it would be the first thing I replaced. You can buy just the end but I would suggest buying the whole unit from GM. If you buy just the end you will have to deal with bleeding the cylinder and it can be a pain to get right.
