KYB's and Eibachs
Moshbmx1
12-27-2006, 04:01 PM
Anyone have any suggestions on running KYB shocks and Eibach springs? Good/Bad?
Greed4Speed
12-27-2006, 06:17 PM
Don't
94/96ZsM6s
12-31-2006, 02:13 PM
i have eibach pro kit springs with kyb agx shock. the combo works great, and i've put 10k on the set up. if i was you i get some bilstiens, there the same price as the agx's. i woudl have done this but they didn't lower the prices until after i installed the set up.
Moshbmx1
01-01-2007, 01:50 AM
I've been reading on the bilsteins and i see that they have a "revalved" version. The price is a little bit more than i want to spend but what is the main difference in them, peformance wise?
kandied91z
01-05-2007, 01:28 AM
eibach and bilstein are the ultimate. koni yellows aren't bad either. kyb might as well get monroe or gabriel.
always faster
01-05-2007, 09:46 AM
Well when it comes to shock you defenetly want a shock that can match your spring rates.
The best are the Koni SA, with those yo can adjust the damper anytime you want from street adjustement to a more agreesive one for the track.
You could also get some Bilstein re-valved to your springs rate.If you dont need an adjustable shock those are the way to go.
I never heard great things about the Kyb AGX on a f-body...
Just remember that you cant install lowering spring on basic replacement shock like Bilstein HD,monroe,gabriel or kyb gr2.
2000GTP
01-05-2007, 11:54 AM
I would stay away from the KYBs, as noted above. Konis would definitely be your best bet, but may be out of your budget. Bilsteins would be the next runner up.
Capn Pete
01-05-2007, 01:39 PM
Can you elaborate on that a little? :think: Also, a friend of mine lowered his car ('96 TA) and ran KYB AGX shocks ... not sure how it REALLY handles, but I know that right off the bat, they didn't even supply the proper hardware with the shocks :rolleyes:. Then by the time he went to install them, they were "stuck" in the compressed position, and had to be "pumped up" a few times to get back to working?! :confused: That doesn't seem like quality pieces to me? :shrug:
Moshbmx1
01-05-2007, 02:48 PM
So if i go with bilsteins and want to lower the car I cant get the HD's and eibachs I have to get the revalved ones?
kandied91z
01-05-2007, 04:03 PM
no you can. the hd's are perfect for the pro-kit and the bilstein sports are excellent with the sportlines. revalves aren't needed and the $1500 bilstein adjustables that outperform the koni's are above and beyond excellent but obviously pricey.
Koni is a great company just a different option and it depends on your taste but gm uses bilstein. i'd go with either of the two that's in your budget in the end.
Moshbmx1
01-05-2007, 04:59 PM
Im going to go with the prokit for springs. Im just looking for a shock that will compliment my springs and not really looking to spend $1000+ on a set-up. I'll do some more checking on the HDs and see what I can come up with. Thanks
Sam Strano
01-05-2007, 06:27 PM
Whoa man..... I have to disagree--with about everything you stated.
HD's are NOT perfect for lowered cars. Actually Bilstein states in no uncertai terms HD's are *not suitable* for lowered cars. Sports are, but they don't make Bilstein Sports for 4th gen's. And Sportlines are all about looks, not any kind of decently working suspension. Further, Bilstein doesn't make ANY adjustable shock for any f-body at all, let alone $1500 sets. Hell Koni DA's aren't $1500 a set. And Koni's start @ $725/set for a 4th gen, even less for a 3rd gen.
Also Bilstein doesn't have a "Revalved" version, they make HD's. Revalves are something I have done on a case-by-case basis to shock to make them control certain springs or uses. Basically I make the Sport valving they didn't care to, but I also do it for the person and use they are going to, not as a one size is good for everyone kind of thing.
Sam Strano
01-05-2007, 06:30 PM
Pro-kit and Revalves would run you about $769--around $795 shipped. Not quite $1000. But you could get better springs for just a little more, like the ones I had built because I was fed up with compromises for handling. Actually, shipped a set of our lowering springs and Revalves comes to just about $824 *shipped*.
Do a search for my springs. I hide nothing, and there are lots of pics on various websites. But short version is the rates and heights are speced by me. They are about 1.25" lower (truly vs. the hit and miss of Eibach's). They are some 35% lighter in physical weight than Eibach's are (about 13 pounds a set).
Moshbmx1
01-05-2007, 09:31 PM
Sam i PMed you a few weeks back asking for some input and I havent had time to give you a call as ive been really busy with work and it is finally slowing down so i will be giving you a call here soon and we can get this figured out.
2QUIK6
01-07-2007, 04:27 PM
Can you explain what hardware was missing? I've never bought a shock that came with anything but the shock or strut itself and the bolts...mine came with bolts.
I've got AGX's on my '95 vert and I have to say I was unimpressed with them, they are alright and they will definitely stiffen the ride up when turn the dial to 4+. They definitely did not make the difference that they made for some of my other cars and trucks.
Capn Pete
01-08-2007, 08:49 AM
That's exactly it, all they supplied was the BOLTS for the rear shocks (for the lower end that bolts to the axle housing) but the bushings that the bolts go through, that go in the end of the shock, were NOT supplied?! :irk: My buddy had the shocks sitting around at least ~2 months (maybe longer? :shrug: ) just waiting to get the stupid mounting hardware :rolleyes:.
After all that, I don't think they turned out to be that great of a shock. I drove his car once, almost 3 years ago, so I can't honestly say how it handled. I know it felt a lot different than mine, but you figure, his was lowered, w/18's, while mine is/was stock, w/16's ..... and in ~15 minutes of driving, I couldn't tell if the rougher ride was just because of the lower profile tires than mine, or what? :shrug:
Just going by the concensus around here, it sounds like Bilstein's or Koni's are really the only good option for 4th-gens?? :confused:
Sam Strano
01-08-2007, 11:50 AM
I'll be around, I don't know when I can return the PM, and I haven't read it yet.... but I can't recommend anything by way of e-mail anyway. Just call me @ 814-849-3450, if I don't answer I'll call you back. I'm pretty much buried, so please be patient. :)
As for "Just going by the concensus around here, it sounds like Bilstein's or Koni's are really the only good option for 4th-gens?" Basically, yes. But that's not really any different than when you look at say, tires. There are many more not so good ones than really good ones. :) And FWIW, saying "Bilstein" is very vague. Remember there are 3 "Bilstein" shock sets you could choose from (actually, technically 4).
Moshbmx1
01-08-2007, 11:25 PM
Yea, I will be giving you a call here in the next week or so and we can figure out what road to take.
ZL1modified
01-10-2007, 06:31 PM
so your saying these don't compliment each other?:confused:
http://www.slponline.com/view_product.asp?P=70002
Sam Strano
01-10-2007, 06:38 PM
You might want to compare apples to apples. Those *aren't* HD's, but SLP valved versions. And the springs *aren't* Pro-kits or Sportlines, but again SLP versions that Eibach happened to build.
Basically, I didn't say those don't compliment each other. You are assuming I did because I told you HD's and Eibach's don't compliment each other. Those aren't either of the forementioned items.
ZL1modified
01-10-2007, 06:51 PM
sorry someone like me wouldn't know that... hense the question... it's hard to tell from a picture and a brief statement...
thanks for clearing up my cofusion...:cool:
Greed4Speed
01-10-2007, 07:00 PM
BUT, if you READ on the same page with the picture you linked.
"This new package combines our #70008 Bilstein shocks and #70009 Eibach springs to create the ultimate dual-purpose suspension upgrade for 1993-2002 F-Bodies. Custom designed to SLP’s specifications by their respective manufacturers, these pieces fuse race-quality responsiveness at the track with a firm but comfortable ride in everyday use. Best of all, you’ll save more than $20 over the cost of buying the parts individually"
ZL1modified
01-10-2007, 07:03 PM
okay, you got me!!! :bow: my bad...:p i didn't know they actually did more work to them... :shock:
