ajlew9428
12-27-2006, 01:54 AM
Im doin a rear end swap from 323 to 373 w/ eaton posi. Will I need a reluctor ring so that my abs lights dont come on?
reluctor ring?ajlew9428 12-27-2006, 01:54 AM Im doin a rear end swap from 323 to 373 w/ eaton posi. Will I need a reluctor ring so that my abs lights dont come on? ajlew9428 12-27-2006, 12:52 PM anybody? Performabuilt 12-27-2006, 01:11 PM well if your original rear had one for the abs then yes you will OBE1 95Z28 12-27-2006, 02:42 PM If your car came equipped with traction control, then your reluctor gears are located out at your axles near the disc brake setup. Non-traction control cars have the reluctor mounted in the differential. Injuneer 12-27-2006, 04:26 PM There's an article in Pontiac High Performance magazine, October and November 2006 on rebuilding the 7.5" 10-bolt. They used an Eaton, and show how to mount the ABS reluctor from the old carrier. ajlew9428 12-27-2006, 11:50 PM thanks for the help. | ||
