93 4mula
12-24-2006, 11:47 PM
I have the BMR K member that uses the factory power steering rack and pinion, its this one.. PART# KM002 - Standard tubular k-member with LT1 motor mounts and factory power rack-n-pinion mounts. My question is that Im wanting to go to manual steering. Will either of madmans manual steering kits bolt up to this k member or am I going to have to change the whole k member?
OBE1 95Z28
12-25-2006, 02:21 PM
According to BMR's website, it's a different part number:
PART# KM002 - Standard tubular k-member with LT1 motor mounts and factory power rack-n-pinion mounts $499.95
PART# KM002-1- Standard tubular k-member with LT1 motor mounts and Pinto manual rack-n-pinion mounts. Manual racks available below. $499.95
93 4mula
12-25-2006, 05:19 PM
Yea but I think Madmans rack and pinions are suppose to be like direct replacement.
OBE1 95Z28
12-25-2006, 09:14 PM
Safest thing to do is contact Madman :)
Hawk944
12-25-2006, 10:14 PM
The madmans will work with any k-member, aftermarket or factory. Only down side is that they're 600 bucks. I just swapped k-members with BMR and bought the flaming river kit.
93 4mula
12-26-2006, 01:28 AM
So whats the difference in the two bmr k member kits? One says its for manual steering or factory ps. Thats what through me off.
NOSCaMaRo
12-27-2006, 09:43 AM
The manual rack should use a different mount then the power steering rack. You may just need to weld a small bracket on the K-Member for the manual rack.
