Fuel gauge jumps around
SS1156
12-23-2006, 06:40 PM
I did a search and did not find anything specific to my problem. I was driving the car today and noticed that the needle in the gauge was jumping around quite a bit. I know that the sending unit is a float design but the needle was moving too much. Do you guys think the sending unit is going bad? The car only has 56k on it. If I need to replace it, can I get one with a walbro 255lph pump already in it? thanks for any help you all can send.
OBE1 95Z28
12-25-2006, 12:34 PM
The sending unit and the pump are separate parts that mount next to each other in the tank. Your problem may be a wire issue; Shoebox has a troubleshooting procedure here: http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
