70 hp out of ignition sound too good?
94_firechicken
12-23-2006, 06:26 PM
I was talking to a guy at a machine shop that was cutting my stick shift to make it shorter and he was asking me what type of engine I had. I told him that I had a firebird and that it was a 94 with an LT1. The moment I told him, he said that they where really good engines except the ignition really holds it back. If I were to replace the ignition in the LT1 he said that it could free up 70 to 80 hp easily. I didn't really believe the guy, but he had built 1000 hp chevy short blocks for racing cars more than once, so he must have known what he was talking about. He kept trying to explain it to me but it only confused me more.:confused: Anywho, does this sound right? Getting 70-80 hp just from ignition? He told me that it should be the first mod I do to the car before slapping anything else in it.
396D1SS
12-23-2006, 06:28 PM
I wouldnt let someone like that touch my car. he is full of **** tell him to lay down the crack pipe
mdacton
12-23-2006, 06:33 PM
if the guy knows his stuff then you missed something somewhere...you either did not understand what he was telling you or he is an idiot
my guess is if he would take time out of his day to cut a shifter....he was probly drinking wild irish rose and smokin a $5 giblet
94_firechicken
12-23-2006, 06:34 PM
He was talking really specific though, saying how the ignition coils shrink at 4200 rpms, and by getting the MSD set up (the whole gig), that it could easily free up 70-80 hp. I dunno, I'm going to go back to that guy to see if he can write down what he told me :P
mdacton
12-23-2006, 06:37 PM
yeah do that...I think most people have all the ignition stuff and get about a zero h.p. gain its good to have but it doesent really make h.p.
396D1SS
lmao, MSD ignitions are usually used for boost / nitrous applications to help prevent detonation. The TRUTH is they will net you around 1rwhp
more of a safety feature if you ask me
I am running the msd digital 6 btw and it didnt gain me any faster track times after the install
mrmint69
12-23-2006, 07:01 PM
Maybe a 1000 hp engine with a stock ignition would only make 925 hp and 1000 hp with an upgraded one. Trying to get in his head, if i really can:alert: I got the whopping 1 hp gain but then added the supercharger so it is worth every penny.
speed_demon24
12-23-2006, 07:32 PM
youll gain exactly 0rwhp over the stock ignition, and don't let that guy come within 20ft of your car.
shoebox
12-23-2006, 07:40 PM
He might as well have said 70 MPG, 'cause 70 HP ain't gonna happen [either]. :no:
rskrause
12-23-2006, 07:57 PM
It takes more electrical energy to make a spark with high cylinder pressure (i.e. boost). That's the main reason a blower car, or a very high compression race engine needs a better ignition. The old (early 80's) GM HEI systems would crap out about 4,500rpm. Maybe that's what he was thinking of when he heard "LT1"?
Rich
roguedriver
12-23-2006, 11:03 PM
Was his last comment "i'm an MSD dealer you know...."?
Ken R.
2000GTP
12-24-2006, 03:22 PM
Let me know what ignition system it is, I'll dump this Mallory piece of junk in no time.:lol:
RE AND CHERYL
12-24-2006, 10:06 PM
I actually picked up about 300hp when I replaced my stock ignition with a Delteq.:cool:
My results might be a bit skewed though, because my stock coil was bad at the time. :D
byrons1502
12-24-2006, 10:13 PM
this one hit a nerve. i think ther was a problem with the old stuff if that was the case. it could happen but not looked at the REAL reason why it gained so much. or he misread the numbers somehow. soem guys are good at carbs and don't understand fi that much
RE AND CHERYL
12-25-2006, 01:44 PM
Unless there is a sinificant problem with the ignition system it would be unlikely to even pick up 7hp. The oly way to pick up 70hp would be to way screw up the timming maps. The old large cap HEI systems (in stock form) were the only ones I know of to fall on their face above 4500rpm.
mdacton
12-25-2006, 05:30 PM
I have run the old sty;e in cap HEI units (modded stockers) to 8500+ r.p.m.
the did fine
maybe he was talking about an early 70's LT1 with points
