SnakeSlayinZ
12-23-2006, 10:09 AM
I have A 1994 Camaro that I fixing up and I really want twin turbos on it. I just want to know what should I do to the motor to handle about 30lb of boost or if I should just buy a new motor.:confused:
Need help on LT1 twin turbo setupSnakeSlayinZ 12-23-2006, 10:09 AM I have A 1994 Camaro that I fixing up and I really want twin turbos on it. I just want to know what should I do to the motor to handle about 30lb of boost or if I should just buy a new motor.:confused: bmwmcars 12-23-2006, 10:41 AM a full race prepped block, or aftermarket (dart, etc) billet 4-bolt main cap conversion forged crank billet rods great pistons turbo cam heads/intake to get the most out of the turbos custom twin turbo headers turbos downpipes wastegates intercooler and plumbing boost controller major fuel system upgrades injectors serious drive line upgrades (differential, trans, etc) lots and lots of tuning basically, every component fo the driveline will have to be upgraded and/or replaced. 30psi with twin turbos is by no means an inexpesive or simple proposition. i know this first hand, as right now i am building a twin turbo motor that should easily make 1500hp. this, of course, is just my opinion on the matter. good luck with your project. engineermike 12-23-2006, 02:16 PM You know, of all the very high hp combo's out there (up to 1200 rwhp), I have never heard of anyone running over 30 psi on a v-8. I'm sure they exist, but pretty much anything slower than 8.00 in the quarter doesn't run over 30 psi. Something tells me you don't yet fully understand what you're getting into. Start out at 5 - 6 psi and I think you'll re-adjust your goals. Pyrodawg 12-23-2006, 02:35 PM agreed... 30 psi on a TT V8 is going to be rediculous... notice 4 bangers are making anywhere from 5-700whp with 30psi... so just some stupid math here... double that for a V8 = unneccessary LT1-TA 12-23-2006, 03:28 PM You know, of all the very high hp combo's out there (up to 1200 rwhp), I have never heard of anyone running over 30 psi on a v-8. I'm sure they exist, but pretty much anything slower than 8.00 in the quarter doesn't run over 30 psi. Something tells me you don't yet fully understand what you're getting into. Start out at 5 - 6 psi and I think you'll re-adjust your goals. Well on top of that fact you hav no idea what you are getting yourself into. You would be surprised at how much that post revealed your knowledge on what you are asking for. Listen to engineermike.. he knows his stuff... Read a lot. READ A TON! Even if you start at something small like 6 psi on a stock motor, you must read and learn. The only way you can get what your asking for now with your current state of knowledge, is to drop the car off with a blank check at a reputable shop. Then you will most likely kill yourself when you get the car back. Chrisbequick 12-23-2006, 04:28 PM I have A 1994 Camaro that I fixing up and I really want twin turbos on it. I just want to know what should I do to the motor to handle about 30lb of boost or if I should just buy a new motor.:confused: Stick to bolt-ons. -Chris CrazyLT1 12-23-2006, 04:51 PM Ya I'm pretty sure he doesnt realize at all what it takes to achieve that kinda power. Stroker396 12-23-2006, 06:51 PM Everyone is correct in there assesment. How about telling him that this kind of setup done properly would run 35 to 50 thou to build! I knew a guy who built one (third Gen) and ran 300mph at the Bonnaville Salt Flats. Yep it is nothing more than a race motor. Cheers SnakeSlayinZ 12-23-2006, 11:27 PM Thanks for all your guys help. when I said 30 psi I think that was a typo I meant to say about 18psi total from both turbos. But still thank you for all your help you have been very helpful. OFI 12-24-2006, 01:38 AM Thanks for all your guys help. when I said 30 psi I think that was a typo I meant to say about 18psi total from both turbos. But still thank you for all your help you have been very helpful. It doesnt matter how many turbos you have. If you have each turbo running a 10lb spring that dont mean you have 20psi. You still only have 10psi total. ComptonZ28 02-20-2008, 06:06 PM OK, so is tha TT set-up worth it, from a street level? I been gettin' mixed reviewz... LT1-TA 02-20-2008, 08:06 PM OK, so is tha TT set-up worth it, from a street level? I been gettin' mixed reviewz... bang for buck? No GreasyB 02-20-2008, 09:51 PM Sounds like you do not need to be getting into the world of boost. Do some more research. RealQuick 02-20-2008, 11:34 PM You guys a brutal!!! Haha ;) In reality, TT's are great, but can be much more complicated then a single. Forget boost level (psi) for a moment, what are your goals for the car (hp wise or track times wise). Geoff Chadwick 02-21-2008, 03:15 PM 18psi Even at 18psi - look at putting $30,000 into the car, assuming you do a good chunk of the work yourself, and *all* the installation labor. If you're going to bragging rights "I've got a Twin Turbo such and such with 30 psi", thats one thing. If you want a drag car, thats another. | ||
