Need help with Twin Turbo setup
SnakeSlayinZ
12-23-2006, 09:36 AM
I have A 1994 Camaro that I fixing up and I really want twin turbos on it. I just want to know what should I do to the motor to handle about 30lb of boost or if I should just buy a new motor.:confused:
jasonisdn
12-23-2006, 09:52 AM
youneed to post in the forced induction area. they can help you, btw to hold 30#'s i hope you got a ton of money.
SnakeSlayinZ
12-23-2006, 10:06 AM
Thank you
96capricemgr
12-23-2006, 10:50 AM
Boost is a measure of how much air the motor is NOT getting. 30lbs is ricer numbers or all out race on a domestic V8.
A well built LT1 on 15lbs is capable of 9s.
Combination Motorsports LT1 Impala is running 28-30lbs from a blower and runs low 9s also has traction problems past mid track.
JC95Z
12-23-2006, 09:08 PM
Basically all you would need to do is tune the flux capacitor to make sure you are getting the proper 1.21 jiggawatts.:p LOL. I think you are way over shooting a practical amount of boost,(unless you are loaded). If you have to have "Twin turbos" I would just just do it like the sts turbo setup just run dual exuast like on the rustangs and build your own cutom setup.(If you can weld)
zx1216
12-23-2006, 10:22 PM
carefull, your post may be deleted..., anyway this guy needs to do a lot more research and figure out what is doable or even practical. First of all twin turbos are a waste of time, what do all the high hp supras and rx7's run? Thats right one huge single turbo, sure it takes a while to spool but with at least 350 cubes there not bad. Also the guy above is right saying you are runing xx pounds of boost is a ricer measurement. A t-76 and a t-25 from a 2g eclipse can both make 15 lbs of boost, you bet your ass the t-76 is flowing a hell of a lot more air though...take a few months and search this site in and out, you may be changing your mind.
SMOKNZ
12-24-2006, 07:54 AM
With the right configuration, singles can be made to work well (TTi's LT1 kit excluded). Twins on a V8 are hardly a waste of time. There are many LT1's and LS1's sporting twins and making a lot of power. Why should we all ditch them and go sport T106's so we can be as laggy as supras??? From a fabrication standpoint single vs. twin it isn't much different. The hardest part of a kit is generally the headers. After that it is just large diameter tubing with easy access to weld anything needed! Hardly a waste of time! Build your own kit someday, it's fun!
zx1216
12-24-2006, 01:19 PM
ok, flame away i don't care, if he thinks he's going to run 30 psi out of twins on a lt1 i don't think he knows what he's geting into in the first place, nonetheless has the skills to fab up a twin turbo kit... I have actually though of making a turbo kit for my z but i'm still in school and its kind of a daily driver for me, also i don't have 5k and a tig welder to do it the right way. Anyway not to be a jackass about the whole thing, he just has a lot to learn, i by no means am an expert on any of this, just pointing out his goals are unrealistic.
Z8'S
12-24-2006, 02:53 PM
I'm looking for 30 +lbs of boost out of my LT1 with twins.Pretty sure I know what I'm getting into. Not for the weak at heart or finacially straped. Car will be complete early March 07.
zx1216
12-24-2006, 07:15 PM
sounds good man, have any pics? Yeah geting into the 8's with an lts will require some boost, best of luck on your new setup
Z8'S
12-24-2006, 10:52 PM
My car has been in the 8's for a couple of years now. I am looking to run in the 7's at 180mph + This year. My current setup is at my FQuick site .The car is being converted to turbo now and will add pictures when more is complete,http://www.fquick.com/Z8s
byrons1502
12-24-2006, 11:43 PM
z8's props on the bad ask car
byrons1502
12-24-2006, 11:45 PM
do race in lower mich or upper indiana. maybe i have seen you. most of the racers i hang out with are low 9's to high 10's but can't understand my love for fi instead of carbs. sorry for getting off post
Z8'S
12-25-2006, 12:01 PM
Thanks for the props !
The car has been run at 41 in Morroco many times .Plan on running the friday night DragRadial class at Milan in 07.
robvas
12-26-2006, 03:32 PM
What kind of fuel is used on a 30psi turbo LT1 setup? Pure meth?
Z8'S
12-26-2006, 05:24 PM
VP C-16
Brady
12-28-2006, 08:05 PM
looking good brother! :bow:
