94 engine swap
yep,350L_S_1
12-22-2006, 02:51 PM
does anyone have any experience in putting an lt1 in place of a 3.4L V6? What all am i gonna need to do this. will i need an lt1 engine cradle? and i can still use my a4 with this motor, correct? thanks for any help!
2000GTP
12-22-2006, 03:07 PM
You will need a new k-member (cradle) and the LT1 tranny because the bellhousing bolt pattern is different between the two.
FunkZ
12-22-2006, 05:46 PM
http://www.v6conversion.com
yep,350L_S_1
12-23-2006, 12:08 AM
a corvette lt1 is the same block so it should fit in a 94 camaro, right? as long as i got a tranny for it should work. also, am i gonna need to get a new radiator? one that came from an lt1?
FunkZ
12-23-2006, 06:17 AM
The parts list at that v6 conversion site tells you everything you need.
