Fuel pump access door panel problem. pics
TJsrh420
12-21-2006, 05:19 PM
my problem
http://img293.imageshack.us/img293/5608/picture013ax9.jpg (http://imageshack.us)
WTF is that black line all the way to the left. i thought my fuel pump was leaking so i researched and cut a hole out and i kinda cut the top of that line. i wounder if thats where the fuel is comming out. HELP. all other lines are connected and i have no idea where it goes:confused:
T56LS102
12-21-2006, 06:13 PM
Its a breather hose
TJsrh420
12-22-2006, 10:48 AM
but wtf should it be connected to cause my car is filling up wit vapors and i can't take it. help
krispy
12-22-2006, 01:11 PM
well now its definitely gonna fill with gas fumes because you cut a hole in the sheet metal :)
BrokeMofugga
12-22-2006, 02:33 PM
Ive always done the fuel pump the hard way,by taking the tank out:D .toyota supra,pontiac bonneville,91 forumula firebird.sometimes its a pita.but sometimes it a breeze.later
Injuneer
12-22-2006, 03:16 PM
Is it possible the vent hose from the canister to the engine had been removed from the canister and pushed back up over the fuel tank?
This is a 97, and there's no "extra" line:
http://www.cardomain.com/member_pages/show_image.pl?bg=CCCCCC&image=http://memimage.cardomain.net/member_images/12/web/348000-348999/348183_108_full.jpg
But.... look at the "upper" metal line, which you didn't uncover.... could that possibly be the hose that connects there, and its fallen off?
krispy
12-22-2006, 06:06 PM
I was doing this eariler on today, from left to right;
the 1st metal line connects to a quick connect
the 2nd one is connected as shown
the 3rd one connects to a quick connect
the 4th one takes a left hand turn then connects to a straight rubber pipe
that rubber hose is really weird
Soccerbum21
01-13-2007, 12:44 AM
just did my fuel pump today and i didnt see anything like that extra line you got there.
and i cut my access door a little bit more towards the back seat to get access to the quick connects.
best bet would to be to get a buddy to jiggle the line while you're under the car trying to see which one is moving. and double check that all four of your hoses are connected
