mrmint69
12-20-2006, 09:23 PM
I have the factory injectors. Is there a bigger size i can get without having to get the computer reprogrammed?
Bigger injestors?mrmint69 12-20-2006, 09:23 PM I have the factory injectors. Is there a bigger size i can get without having to get the computer reprogrammed? lethal93ta 12-20-2006, 10:17 PM no matter what injectors you put in you should program for them. ajlew9428 12-21-2006, 02:38 AM what he said mzgp5x 12-25-2006, 10:26 AM I have gone to 30#/hr with the stock PCM flash (Hypertech). It ran OK. When I went to 36#/hr, the car runs rich due to a PCM cal of 24 in the flash. Very difficult to start. I purchased LT1-edit. Now running 72#/hr Low-Impedence Siemans with an Acceleronics driver box. (1997 - 383/D1) lethal93ta 12-25-2006, 11:26 AM go ahead and run 30s on stock programing, wash the oil off the cylender walls and take the rings out from to much fuel. running rich is just as bad as running lean. OBE1 95Z28 12-25-2006, 12:38 PM I have the factory injectors. Is there a bigger size i can get without having to get the computer reprogrammed? Dynoing tuning of a blown car is cheap insurance to keep the engine healthy. I would get a set of 42 # injectors and have the car tuned. | ||
