Spray out of the hole/ don't spray in 1st Q's.
Old Dec 17, 2006 | 08:22 PM
Bayer-Z28's Avatar
I tried a search, but didn't turn up much...
I am still doing my nitrous research. Why are you not supposed to spray in 1st? And that ties into the other question; if you're not supposed to spray in 1st, then why/how do people spray out of the hole? Is that with auto's? -Spray after stall RPM?
-Thanx.
Old Dec 17, 2006 | 08:29 PM
MEAN LT1's Avatar
-Thanx.
Usually people dont spray in first is b/c either 1. they cant get traction in first gear on the bottle or 2. They want to save the rear from going out. Or a combination of both.
Old Dec 18, 2006 | 09:36 AM
EkS's Avatar
EkS
...or 3. They don't want to break their transmission.
Old Dec 18, 2006 | 12:54 PM
Angelis83LT's Avatar
Spraying in first also would probably make you need to shift pretty quick out of first into second... probably want a little more gear than what first has to offer.
Old Dec 18, 2006 | 01:45 PM
Javier97Z28's Avatar
Moderator
or 4. They're pussies.
Old Dec 18, 2006 | 01:55 PM
69gto96z's Avatar
I was going to get a Mallory 685 for my n2o kit, will I need to get another box to lock out first? I spin to much with the 4.10's already, and adding nitrous in first wouldn't be a good idea.
Old Dec 18, 2006 | 02:00 PM
Soccerbum21's Avatar
hahahha, awesome
and i spray my way to 1.50's outta the hole!
on a serious note, i'm pretty sure it really eats up the band in the trans when you spray through the 1-2 shift. but i still spray mine on launch
Old Dec 18, 2006 | 03:22 PM
Moshbmx1's Avatar
I spray mine through 1st (auto trans) I blew it up once but i knew it wouldnt hold, it was already slipping. I had to get some stronger bands and clutches and now its good to go. Im running the mallory box and not spraying before 3000 so i have a little time but not much
Old Dec 18, 2006 | 03:30 PM
transam001's Avatar
i have a friend who sprays a 150 shot out of the hole with a cc305 cam and runs 10s. stock trans and rearend. has used this setup for 2 years now. has micky's on the back.
Old Dec 18, 2006 | 03:34 PM
69gto96z's Avatar
My car is an M6 so I will not be spraying through shifts.
Old Dec 18, 2006 | 03:38 PM
Bayer-Z28's Avatar
Or just don't have $$ to replace anything...
.... All of these make sense. THanx guys/gals.
Old Dec 18, 2006 | 04:50 PM
speed_demon24's Avatar
Then you should have put the $$ into building up your drivetrain instead of spending it on nitrous.
Old Dec 18, 2006 | 05:02 PM
69gto96z's Avatar
Not all of us want it to spray out of the hole and cut good 60 fts. Some people like to build their car for the street, not the track.
Old Dec 18, 2006 | 05:44 PM
396D1SS's Avatar
cutting good 60 ft's makes a faster street car. The track for some is only used as a tool to get their street cars dailed in. I can warm up a pair of et drags and come out of the hole with a 250 shot on on top of 450rwhp and holeshot 900hp poopras so bad they will not think about catching up
Old Dec 18, 2006 | 05:53 PM
69gto96z's Avatar
I am running a stock 10 bolt with a m6 and 4.10's. I am afraid i may snap the axle spraying out of the hole.
